- Thank you received: 3
GPZ1100 head
- notaduc
1980 (mostly) KZ1000
- MFolks
- Thank you received: 540
- PLUMMEN
- Thank you received: 104
- larrycavan
- Visitor
So, what is differnt that makes this a higher flowing head?
www.flowbenchtech.com/porting/CRH/kz-data.htm
- notaduc
- larrycavan
- Visitor
What's the intended use of the bike?
- Polar_Bus
- Thank you received: 7
the 83-85
I have an '84 SUB head and I can tell you it's not the best "street" head. You give up some street "versatile" midrange torque. However at the dragstrip where that head can really breathe now you have the advantage. My GS1100E has a bit more midrange "roll on" torque than my GPz. But get the GPz up around 9K, and that engine really starts to haul the mail !!
Bikes:
'84 GPz1100
'06 HD Fatboy
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- 9am53
- homebrew, and some bbq
I don't know about that, I have one on my bike that is flowed to the teeth and running .420 lift cam. I love mine. It runns like a Raped Ape. and YES I am useing BS34s on it. The trick is to match and the cams right. My cams are asimetrical and the exhaust cam is retarded. This gives me metter lower rnd torque.
lol, you're retarded :woohoo:
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
- TeK9iNe
- What did you do!?!
- Thank you received: 28
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- larrycavan
- Visitor
I don't know about that, I have one on my bike that is flowed to the teeth and running .420 lift cam. I love mine. It runns like a Raped Ape. and YES I am useing BS34s on it. The trick is to match the cams propperly. My cams are asimetrical and the exhaust cam is retarded. This gives me better lower rnd torque.
BINGO!
It's the RIGHT cams that make or break the deal.
Stock vs Stock, the situation is exactly like Polar describes it. GS is a mid range monster and the GPz likes to be twisted up..... Kawasaki's are like that, they love RPM.
Nice combos:
Push that GPz head from 83 to 95cfm. Swap out the GPz cams for something like Cam Motion Z1 and you'll transform the GPz into something that will put a smile on your face constantly.
Top it off with a rack of CRS33, RS34 or Pogue Machine taper bored throttle bodies with adjustable pressure regulator..... Can't go wrong with any of those choices.
You want "crap your pants" upper RPM pull & willing to sacrifice some lower midrange.... go with Web 109 grind.
I've seen 81GPz11 run 10.80s with porting and swapping out the EFI to 29 smoothbores. And that was without a bar or slick. Stock cams, pistons...only head and carbs.
- CoreyClough
- GPz550 Addiction
- Thank you received: 80
It all depends on where you want the power to come on.
Some day I'll have to 1/4 mile this bike. All stock, including airbox and exhaust, it will run 12.74 @ 104 mph, as my friend did this consistantly.
Carry on, this is good reading. I've subscribed!
'85 GPz550(ZX550-A2)
