Original engine case #'s (76 KZ900 B-LTD)
- Lennymon
- Lennymon
03 Feb 2011 16:01 #428222
by Lennymon
Original engine case #'s (76 KZ900 B-LTD) was created by Lennymon
OK i bought my 12/75 (76 KZ900 LTD) back in 1984 and i am the third owner and i met the 1st owner and he did not tell me he replaced the case but according to kz rider my case # is not original- 074555. I have been on ebay and found a case that is a 105### that is from a 76 LTD w/10,000 miles but this tells me it could be a A-model correct? I have found 2 A cases that are above #'s 086001 that match kz riders #'s for a A model but a B(LTD) should start at 108503 is this correct info or is my case original? I need a case because it broke below the shift selector causing the trans to come in and out of (jerks)3rd,4th gears. I am still building a KZ900 A model and can find a case for it on ebay(Z1E090007) no problem even though i have a spare 1974 case but i want to have matching case #'s for both bikes can anyone help me with this?
- PLUMMEN
- Thank you received: 104
03 Feb 2011 16:16 #428225
by PLUMMEN
Replied by PLUMMEN on topic Original engine case #'s (76 KZ900 B-LTD)
not sure about the numbers,but cant you have broken case welded?
- vernons
- Thank you received: 12
03 Feb 2011 16:16 #428226
by vernons
Replied by vernons on topic Original engine case #'s (76 KZ900 B-LTD)
- Lennymon
- Lennymon
03 Feb 2011 16:23 #428229
by Lennymon
Replied by Lennymon on topic Original engine case #'s (76 KZ900 B-LTD)
I already welded it up years ago and it broke recently again. I took the pan off and it broke threw and around the welds. The welds arent the greatist but i would like to remove the case and fix while i put another in Thanks!
- Lennymon
- Lennymon
03 Feb 2011 16:25 #428231
by Lennymon
Super cool thanks , so my 074555 is maybe a 75 case.
