- Thank you received: 11
valve installed length
- kawi810
03 Feb 2011 06:36 #428117
by kawi810
original owner of a 1984 gpz 750
1985 turbo 750 stock, being restored.
1984 gpz 750 with 810 cc wiesco's megacycle cams(471-10) 34 mm flatslides v&h pipe ported head dyna ignition. bottom end, crank case from turbo 750 and sprockets.
valve installed length was created by kawi810
what is the correct installed valve stem length for a gpz 750 with 1.110 base circle cams for the middle of the shim range?
- larrycavan
- Visitor
04 Feb 2011 14:04 - 04 Feb 2011 14:05 #428473
by larrycavan
Replied by larrycavan on topic valve installed length
kawi810 wrote:
First, verify both cams are 1.110 base circles. I've had GPz 750's with smaller base circle exhaust cams.
If they're both 1.110 37mm should work.
Just make sure you verify both cams I got bit on a valve job because the FSM is wrong. I had to redo the exhaust and sink them more. I didn't have the cams for the head though so I didn't know the exhaust had smaller b/c.
I had already tipped all the valves for 37mm installed height..... Live and learn...
Last edit: 04 Feb 2011 14:05 by larrycavan.
- kawi810
04 Feb 2011 14:51 #428486
by kawi810
Replied by kawi810 on topic valve installed length
thanks larrycavan .my valves are around 38 mm and i need a valve job to freshen them up .how much can i tip the valve stems(max)?does any body machine the spring retainer for more clearance?or do you just by new valves?
- larrycavan
- Visitor
04 Feb 2011 17:14 #428531
by larrycavan
kawi810 wrote:
38mm for a 750 :ohmy: You're in for a treat.
Well, we've discussed that elsewhere now haven't we :laugh:
I'll say this one more time. YOU DON'T NEED A 38MM VALVE TO FEED AN 810CC MOTOR.
That said, here's some info for you
In situations like that, you may end up needing cams with smaller base circle. By the time you get the valves far enough apart on the seats, you might have them sunk so deep that even tipping the valves down to the keepers becomes not enough.
Re: spring retainers.... If you tip too much off the valves, you have to address bucket to retainer contact. That requires shortening up the shim collars on the retainers.
IMO, you're pissing in the wind but I don't have to stand next to you getting all wet :laugh:
Good Luck and may the Force Be With You!!
- kawi810
04 Feb 2011 18:12 #428573
by kawi810
my valve installed length is about 38 mm . stock valves . sorry for not being clear.
- kawi810
04 Feb 2011 18:25 #428578
by kawi810
what i am trying to find out is what is the max. length before i have to junk these valves and by new ones.i hope i made my self clear.and do i have to by stock kawasaki valves or are there aftermarket ones ?
