\"ART\" pistons?
- RollingStock
\"ART\" pistons?
10 Oct 2005 13:24
anyone ever heard of these?.. are they stock(for my 73 z1)?..
i just pull a set off my z1 900 they look new..also i looked up a head gasket for my bike and it says that they had a 2 piece and my bike had a 1 piece. there is also writing in black marker on my crank
73 z1900 street nitrous drag bike(powered but honda)
83 kz750 turbo street fighter project
- Garn
Re: \"ART\" pistons?
10 Oct 2005 15:08
Roll', yes, ART are the correct make of pistons for the Z1.
If your engine is designed for a two-piece head gasket, there will be a milled groove to take a rubber seal around the chain cavity.
RegardZ
RegardZ
1 x 73 Z1 (Jaffa), 74 Z1A, 76 Z900-A4
1 x 73 Yamaha TX500 & 98 fzx250 Zeal
Sydney Australia
Sydney Australia
- wiredgeorge
11 Oct 2005 08:00
I thought the early Z1 engines used a one piece gasket as they didn't have the oil sealing rubber gasket around the cam chain tower. There is a groove the shape of a casket around the cam chain tower if you need to use one of those seal; otherwise a one piece gasket works. And as Garn noted, the ART pistons are OEM...
