- Thank you received: 72
wiseco boring clearance
- turboguzzi
02 Feb 2011 04:37 #427784
by turboguzzi
wiseco boring clearance was created by turboguzzi
time to take the cylinder block to boring
trouble is that i dont have the spec sheet for my 810 kit.
Can anybody tell what's the recommended tolerance for these forged 810/69mm kits?
Thanks in advance
TG
Thanks in advance
TG
- steell
02 Feb 2011 06:02 #427791
by steell
Replied by steell on topic wiseco boring clearance
I think it's this one
www.wiseco.com/PDFs/Manuals/MSeries.pdf
If not look on this page
www.wiseco.com/InstallationManuals.aspx
- turboguzzi
02 Feb 2011 09:35 #427832
by turboguzzi
Replied by turboguzzi on topic wiseco boring clearance
Thanks Steell, that's what i found before posting too....
the first one is two stroke related,
Then went through those links too, not much info either.
Only the FAQ has got a very generic 0.004 for "small blocks", (guess they are talking about chevy's....)
So not very specific info and quite a large clearance compared to the 0.002 i usually go for in cast pistons. my tuner friend recommended 0.003 to allow for the forged blanks.
How does that sound? Anybody installed an 810 kit lately or other wiseco slugs?
"The factors that affect this are cylinder wall thickness, whether the block is filled, the overall compression height of the piston, piston material and thickness, and whether a marine engine is to see fresh-water cooling. Most small blocks get .004 piston to wall clearance and most big blocks get .005 due to the use of our 2618 high-strength alloy."
- Thank you received: 2098
02 Feb 2011 10:23 #427843
by Patton
- APE Jay
- Banned
- Thank you received: 58
02 Feb 2011 13:07 #427887
by APE Jay
Replied by APE Jay on topic wiseco boring clearance
.0015 / .0020"
Be sure the shop knows how to put the correct finish on the hone. Hope it is not an automotive shop.
- turboguzzi
02 Feb 2011 15:22 #427928
by turboguzzi
thanks jay
that's pretty much what i use for cast pistons too, so you say not care too much about these being forgings (or are they? )
Cheers
TG
Cheers
TG
- APE Jay
- Banned
02 Feb 2011 23:22 #428048
by APE Jay
Yes. It is a high silicon forging, so it can run that tight with no problem.
