- Thank you received: 11
Jumps out of second gear
- gearheadmm
- MUCH MORE BOOST..........I mean BRAVO
03 Feb 2011 18:14 #428254
by gearheadmm
General Joeseph Dunford FOR PRESIDENT!!!
69.46.28.106/forum/11-projects/413221-80-kz-1000-st-recycled
Replied by gearheadmm on topic Jumps out of second gear
Schnitz racing, R&D trans, Gast. I've broken 2nd inputs so if your goin in it might be worth it.
- vernons
- Thank you received: 12
03 Feb 2011 18:19 #428255
by vernons
Replied by vernons on topic Jumps out of second gear
hey, i'm glad someone mentioned overshift bushings!!! i remember 30yrs ago when i had a z1 with 1170 kit after we took it to the drags a some,started jumping out of 2nd.. a fellow drag racer give me a brass overshift bushing!! cured all our problems..
for the life of me i can;t even remember exactly where it went??? another rider on here was having that 2nd gear problem.. i pm'd him about overshift bushing but couldn't remember any of the details!!
it was just a simple brass bushing a local machinist made. hopefully this can be tried before tearing into the transmission... hopefully somebody has the specs for the bushing!!
good luck!!
good luck!!
- Fastdave61
03 Feb 2011 18:21 #428256
by Fastdave61
1969 BSA A65F Firebird
2004 BMW R1150RT
1980 Kz1000G1
2008 Triumph Tiger 1050
Bemidji, Mn
Replied by Fastdave61 on topic Jumps out of second gear
Will do, great, thanks a bunch and have a good one!!!!!!!
2004 BMW R1150RT
1980 Kz1000G1
Bemidji, Mn
- Fastdave61
03 Feb 2011 18:25 #428258
by Fastdave61
2004 BMW R1150RT
1980 Kz1000G1
Bemidji, Mn
Thanks Vernon, will try the bushing before I split the cases.
2004 BMW R1150RT
1980 Kz1000G1
Bemidji, Mn
- gearheadmm
03 Feb 2011 18:25 - 03 Feb 2011 18:27 #428259
by gearheadmm
It goes over the shift fork shaft under the trans cover and prevents the shift lever shaft arms from jumping the shift drum. Steel is better. If its jumping out on upshifts these really do help.
Last edit: 03 Feb 2011 18:27 by gearheadmm.
