- Thank you received: 1
will this work?
- Stu Pidasole
- if you aint mod'n, you aint rock'n!
- testarossa
- Thank you received: 82
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
- Stu Pidasole
yeah josh, i have the 900 block and pistons. need piston kit and bore....i wanna just find a 1015 and push it to 1075 if i gatta buy a kit. thanks man. now i gatta figure out what to do with my 900 parts....Yeah Joe, that should be a 1015 cc block. That should work for you, but you need the same size pistons. You have a 900 block and pistons on your motor right now, don't you?
- testarossa
2004 ZX-10R
Angola, IN
- Stu Pidasole
i hear ya...sleeve it, and then i am maxed out as of bore size on the 900 of i understand right. the 1015 can go up to a 11....? if needed.You can turn the 900 into a 1075 also, but you would have to sleeve it.
- stonemaster
- Visitor
- Stu Pidasole
hmmmm, the bikes a 1000, but someone put a 900 block in it sometime back. thinking i should be ok.....better double check that, Cavanaugh told me no, a 900 bore to 1015 would work but a stock KZ1000 would require a case mod if I remember correctly,
- stonemaster
- Visitor
yea a 1000 cases then ur good sorry
- Stu Pidasole
