- Thank you received: 3
1000cc 4cyl, primary diameter.
- notaduc
29 Jan 2011 16:04 #426835
by notaduc
1980 (mostly) KZ1000
1000cc 4cyl, primary diameter. was created by notaduc
I am looking for outside diameter measurements of exhaust header primarys. Both stock and aftermarket.
Thanks!
Thanks!
- keith1
- Thank you received: 2
29 Jan 2011 16:06 #426837
by keith1
Replied by keith1 on topic 1000cc 4cyl, primary diameter.
pm OMR.....hes working on some......
- notaduc
30 Jan 2011 06:11 #427038
by notaduc
Replied by notaduc on topic 1000cc 4cyl, primary diameter.
If anyone with a set of headers could take a quick measurement, would be great.
- Old Man Rock
- Thank you received: 225
30 Jan 2011 06:30 #427042
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic 1000cc 4cyl, primary diameter.
1.5" O.D. is the norm on the majority of after market 4-1 header designs in the risers (head to collector)....
There's a reason for this in exhaust designs... Tunable (steering) of the desired power band... Pipe wall thickness also plays into the equations. Then there's the length of the risers/exhaust end, collector and baffle designs as well for performance gains.
Now before everyone jumps my case here, displacements, cam/P&P head/valve, carbs is where the true power gains are made.
Basically there's a whole slew of variables required in the design that come into the mix...
Can't say for stock for I don't have a stock exhaust to measure from. I would think 1.25" to 1.5" is ~ right.
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- notaduc
30 Jan 2011 06:59 #427047
by notaduc
Thanks OMR.
I work for an exhaust manufacturer (cars), trying to see it we have the tooling for the bender, I had figured appx 1.5" would be the max. The smallest we have tooling for is 1.625.
- Old Man Rock
30 Jan 2011 07:06 #427048
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
1.625" may be ok.... at least to fit into the head port.
The riser to head tubing is normally slightly flanged to seal on the port exhaust gaskets.
Get a cut piece a couple inches long and size to port...
Just to give you some insight...
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
