Stripped oil drain threads
- vosberdv1975
- P21
- Thank you received: 34
Kawasaki KZ 1000 Police (2002) P21
- keith1
- Thank you received: 2
on a 1000 and you get the bonus of getting out years of smeg buried in the corners and finding trinkets that make you say"WTF is this"?.....:laugh:
- DoubleDub
- Visitor
My threads are stripped where my oil drain plug goes. my question is, if I use a self tapping oversized drain plug will that be too long and interfere with anything internal on the engine? i've never tore the bottom end down so i dont know if it hits the Crank or anything at all.
I would be worried about self tapping as there might be metal left when done that sits in the oil pan? I would think chasing with a tap or swapping the pan would be a better route.
- Samwell
- Thank you received: 1
- Old Man Rock
- Thank you received: 225
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- Thank you received: 2098
When done, the signature information appears in all posts, past and future. And may be changed as often as desired.
Here's how to do it:
Click here > kzrider.com/index.php?option=com_kunena&...d=8&id=382004#382317
Meanwhile, the swami says it's a 1980 KZ440.
- DoubleDub
- Visitor
Not sure which bike but isn't your oil drain plug in the round oil filter cover versus the pan itself?
I had this issue when I was 18 and changing the oil in my bike. I think I ended up with 1.5x the correct amount of oil. The elderly gentleman at the Kawi shop was not impressed...he showed me the proper method to change the oil...:huh:
- PLUMMEN
- Thank you received: 104
- vosberdv1975
- djturnz
- Thank you received: 5
1982 KZ750 (4) LTD
