1978 KZ750 Twin bogging down! Please Help!
- BornOnThe4th
27 Jan 2011 20:21 #426306
by BornOnThe4th
1978 KZ750 Twin bogging down! Please Help! was created by BornOnThe4th
I just picked up a 78 Twin and I've got it running but the issue is that even after it warms up I have to keep the choke open. In addition to that when I hit the throttle it bogs down and occasionally backfires.
If anyone could help me with some troubleshooting ideas that would be great, thanks so much!
I'm a new member as well!
- Rainman
- and a little Kaw shall lead them
- Thank you received: 75
27 Jan 2011 20:41 #426316
by Rainman
80 KZ750 H1 - the Kaw calf
79 KZ750 Twin - Miss Nov 2008 KZR calander
79 KZ750 Twin parts bike
78 KZ650 C2 Parts Bike
75 KZ400 Wife's old bike sold
81 KZ440 A2 LTD Wife's new bike
84 Honda 450 Rebel Wife's newest bike
Jim
Quincy,IL
Replied by Rainman on topic 1978 KZ750 Twin bogging down! Please Help!
Welcome, BornOnThe4th.
Sounds like plugged primary jets in the carbs.
Use the Search Forum button at the top of the page for carb cleaning. Member MFolks(and others)have posted wel documented general procedures for cleaning carbs.
Good luck,
Jim
Good luck,
Jim
Jim
Quincy,IL
- steell
27 Jan 2011 22:08 - 27 Jan 2011 22:09 #426342
by steell
Replied by steell on topic 1978 KZ750 Twin bogging down! Please Help!
Carb related for sure, K&L rebuild kits are available at Z1 Enterprises, and other places.
You might want to check out www.armbell.com/forum/index.php?mforum=kz400 also. That's the Kawasaki Twins Owners Forum.
Last edit: 27 Jan 2011 22:09 by steell.
- bountyhunter
- Thank you received: 337
27 Jan 2011 23:28 - 27 Jan 2011 23:29 #426360
by bountyhunter
Replied by bountyhunter on topic 1978 KZ750 Twin bogging down! Please Help!
It's carbs. They needcleaning and tuning up. Also, clean the fuel tank and petcock and install inline filters.
Don't forget to check the diaphragms for holes or slits. Also, check your timing advancer to make sure it's working.
Last edit: 27 Jan 2011 23:29 by bountyhunter.
- Topper
- Thank you received: 133
28 Jan 2011 04:04 #426383
by Topper
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
Replied by Topper on topic 1978 KZ750 Twin bogging down! Please Help!
My '79 kz750 is doing exactly the same thing. I guess a carb cleaning will need to be done before spring.
1979 KZ750 Twin
- BornOnThe4th
29 Jan 2011 15:59 #426832
by BornOnThe4th
Replied by BornOnThe4th on topic 1978 KZ750 Twin bogging down! Please Help!
Hey Jim,
I stripped down the carbs, cleaned them up and sure enough the bike would throttle properly. But for some reason it wont idle it just shuts off. Is that because I need to adjust the throttle settings? Thanks for the help!
Jacob
Jacob
- Thank you received: 2098
29 Jan 2011 18:31 #426909
by Patton
Replied by Patton on topic 1978 KZ750 Twin bogging down! Please Help!
BornOnThe4th wrote:
If not already done, would try using the thumb screw to set the idle at a higher rpm.
Hey Jim,
Jacob
