ok i found a stock gpz 750 cylinder to bore out. my old 69 mm one was out of spec.who do you guys recommend in the tampa bay area of fl to do the work? has any body used pitstop performance? the 810 cc wiseco pistons are in good shape and i just got a new set of rings.originally cycle rama of pinellas park did the work but they only work on harleys now.
original owner of a 1984 gpz 750
1985 turbo 750 stock, being restored.
1984 gpz 750 with 810 cc wiesco's megacycle cams(471-10) 34 mm flatslides v&h pipe ported head dyna ignition. bottom end, crank case from turbo 750 and sprockets.
