- Thank you received: 52
Valve guide material
- TomW
- Keep the blue side up.
Tom
'78 KZ1000B2 LTD stock + Vetter Fairing & luggage
'91 ZG1200B5 Voyager XII, stock
- testarossa
- Thank you received: 82
I'll check the Machinery Handbook for speeds and feeds. You make it sound like quite a challenge. Here's hoping I don't need them. I'm building a table to put the bike up on tonight. Tomorrow I'll start the tear down. Thanks for the insight.
Tom
It shouldn't be too bad. The length to diameter ratio of a vavle guide isn't too high, and the hole isn't blind. Those two issues cause the most complications. I just don't want you to go into this thinking that the stuff is a cakewalk. When you look up the speed/feed in the Handbook, it should be in the third category of Copper alloys with all the phosphor bronze and beryllium copper. Also keep in mind that especially the feed rates in there a optomistic for smaller equipment, but I'm sure you know that. Good luck.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
- PLUMMEN
- Thank you received: 104
- TomW
Tom
- PLUMMEN
- notaduc
- Thank you received: 3
I used to operate manual and cnc machine equipment for a living and wouldn't bother trying to make valve guides unless I had a lot of spare time and could turn them out reliably on the cnc to resell, which is hard to do at a price lower than a specialist already doing it....
Im all for making anything on my own, but some things just arent worth it.
1980 (mostly) KZ1000
- TomW
In my original post I stated I was THINKING about it. I don't even know if I need them yet.
I think if you can do it yourself, and do it right, it is worth it, even if you only make or save $50 over store bought.
- notaduc
I really enjoy manual machining, but, without a very nice lathe with a dro, making 16 of these is not something I would undertake at $9.54 each. Keeping in ming special tooling, and materials needed, plus throw aways...
Maybe with a cnc.
- TomW
Also, manganese bronze. I feel like I remember silicon bronze having better wear characteristics, but manganese having better heat transfer...
Maybe with a cnc.
CNC, Shmee NC. This is the perfect job for a small manual lathe, the kind you should have in your basement. An Atlas, Logan, or South Bend. I have a 12X36 Clausing built around 1964. I love the challenge. Heck, that's why we work on these bikes ourselves. We enjoy the challenge, the satisfaction of doing it ourselves. It's always easier to give the job to an expert, money notwithstanding. I've been screwed by enough expert mechanics to make an attempt at doing it myself a very worthwhile endeavor. There's nothing much else to in the winter in Wisconsin anyway, Can't ride, the beer freezes if I go fishing, might as well make some chips. GO PACK!!
- TomW
You got a 4 valve head on your 'KZ' or 2 bikes?
- larrycavan
- Visitor
Depending on how fussy one gets with the VJ....
There is such a thing as stepping over dollars to save dimes...
JMO
- TomW
We'll soon see if I need them. I've got the bike up on the bench and the cam cover off. I'll do a leak down test tonight and pop the head off tomorrow.
