- Thank you received: 1
First time Engine assembly
- calvin17d
Just about ready to go here. Wondering where it is appropriate to use any kind of liquid gasket in addition to what i have gotten.
My father suggested using "white grease" as assembly lube. I feel this may be true for wrist pins and top end bearings and valve components but was thinking that piston dipped in motor oil sounded better down below.
Thougts? or other tips / tricks? Going to attempt the zip tie ring compressor trick.
1976 Kz900 A4
- PLUMMEN
- Thank you received: 104
get 2-3 cans of good spray carb cleaner and a couple rolls of plain ol toilet paper(yes toilet paper :laugh: )after you run a hone up/down the cylinder to knock the glaze out of there grab a handfull of that tp and spray it down really good with the carb cleaner.
start scrubbing the bores and keep changing tp and spraying down bores with carb cleaner till you dont see anymore black crud coming out.
i like spray on copper coat on both sides of base gasket and valve cover gaskets.smear a little silicone around bottem o passage o'rings before installing cylinder
- Mcdroid
- Gone Kwackers
- Thank you received: 317
Pay particular attention to reassembly of the jugs on the cases...follow PLUMMENs advice and slso make sure the bottoms of your jugs and tops of your cases (the mating surfaces) are very clean as it is really a PITA to have to pull the jugs again to reclean (I speak from a position of strength ).
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- lemo32
- The Price of Cool aint cheap
- Thank you received: 2
1979 kz 1000 06 katana 750
- Hogslayer
- PUFF DADDY
- calvin17d
1976 Kz900 A4
- TeK9iNe
- What did you do!?!
- Thank you received: 28
Its all about the prep and application. Gasket surfaces must be very flat when mating, and VERY clean before applying anyhting to them.
Most people are so paranoid about leaks that they overkill everything. Totally not necessary from experience.
A good copper ringed head gasket requires nothing to be added to it for proper sealing, even in high performance applications. Studs/nuts and proper torque application is most important.
For ALL of the rest of the gaskets including base gasket, use:
Grease of any kind on a head gasket or near high temp combustion areas turns to rock hard carbon, and can cause all sorts of other problems, including making it damn near impossible for removal later. Don't bother.
Use your fingers to compress the rings, its easy. Zip ties and the like just get in the way and slow things down. There should be lots of chanmfered surface at the bottom of the cylinders unless they have been bored out.
Use lots of good oil.
Grease on old fibre gaskets around the crankcase and such is fine and works well for re-use.
Good luck.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- stonemaster
- Visitor
you'll need a extra set of hands, preferably a set with a set of ears attached to it that function.
also those ears need to be attached to a brain that will follow directions. this can be difficult to achieve
hose clamps work well too, though this last time I had a buddy that had a original Kaw factory ring compressor tool, (he was a dealer back in 74) that held all four at once.
- Kidkawie
- I bleed premix
- Thank you received: 245
Everyone has their methods, butI have found that installing all gaskets but head gaskets dry seems to work best.If you check the factory manuals they only use sealants on cases (Kawi Bond and Yama Bond etc).I have tried many sealants and Gaskacinch by Edelbrock works great!Buy a small can or tube of assembly lube thats what it is designed for ,not sure all white greases are intended to be mixed with motor oil. KAWASAKI MAN SINCE 77
+1 to all that ^^^
Not all white grease is the same. Make sure you buy "assembly lube".
I like a thin coat of engine oil on pistons and bores and bearings before assembly.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
- Motor Head
- Thank you received: 391
- larrycavan
- Visitor
I use soap and water after honing, cleans all the bits of crud out, dont see the zip ties working for ya but they might, start with the inside pistons and work your way out, as far as the white grease, a thin layer is good but some people go crazy with the stuff, could affect tolarance and torque if applied to heavy, go slow, and don't be afraid to take something back apart if it don't feel right, better to be safe than sorry, good luck!
BINGO
HOT SOAPY WATER to clean that block and a bottle brush. Then blow it dry and spray the bores with WD40. Then take a clean white cloth and rub the bores until the rag stops discoloring.
Light coating of oil on he piston skirts & rings. Just enough to give them a film. After block is installed, take a paper towel and wipe every bit of oil you can from the bores before you put the head on. Turn the motor over several times and keep wiping the bores...
Go the the auto parts store and get a bottle of lifter lube for the cam bearings and cam lobes.
OIL your cam tower bolt threads before you put the caps on.
- calvin17d
I will likely apply some clean motor oil to the pistons to please the old man.
Thanks guys!
1976 Kz900 A4
