Exhaust Question
- BIGKEVIN
Exhaust Question
20 Jan 2011 16:41
I have a 1976 KZ900 with a 4 into 1 Vance and Hines pipe. I just got the bike a couple of months ago. While working on it this winter, I notices that where the header pipe connects to the rear portion, the megaphone, there was some clay like stuff to stop the exhuast leak. There is no clamp or gasket. Is there a place that I can order the gasket or clamp to connect to two together properly ? Also, I noticed that some the studs where the header connects to the engine are stripped/rusted. Are all of the studs screwed into the engine ? I plan on replacing all of the studs.
1976 KZ900
2006 ZX6R
2006 ZX6R
- Mcdroid
- Gone Kwackers
Re: Exhaust Question
20 Jan 2011 16:53
The V&H I have may be similar to the one you have. The muffler slips on to the collector BUT the muffler does not have a split end (whereas the muffler on a Kerker does have split tabs...which a clamp compresses making a seal). Absence of those splits on a V&H will not allow the pipe to be compressed around the collector...hence the use of some sort of sealing compound. As for replacing exhaust studs, I think there are a number of threads on this forum that will aid you...and they do thread into the head.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- hocbj23
20 Jan 2011 16:55
My Vance and Hines is slip fit-the megaphone just pushes up onto the headpipe.No "goop" required.There is a bracket that is bolted to the frame to keep the megaphone from slipping off
- andy9802gt
- If it tastes that good, eat it yourself.
20 Jan 2011 16:59
Use red RTV silicone(the high heat stuff). I run a medium sized bead around the inside of the muffler and a smaller one around the end of the collector, slip them together and tighten the mounting bolts, let sit for 24hrs minimum, and you'll be good to go. Don't be suprised when you start it and it blows the dried excess out the end of your pipe.:laugh:
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
20 Jan 2011 16:59 - 20 Jan 2011 17:01
BIGKEVIN wrote:
V&H 4>1 are designed to fit closely without needing a clamp or gasket.
Could apply High-Temp Copper Permatex sealant. But don't overdo it. Just use a thin strip around header where muffler will barely push over and cover the sealant strip when the muffler is being installed. This is so it may be taken apart in the future if desired.
The exhaust studs are replaceable.
Z1E carries the exhaust studs.
Click > www.z1enterprises.com/detail.aspx?ID=100
Last edit: 20 Jan 2011 17:01 by Patton.
- BIGKEVIN
20 Jan 2011 17:05
I have already ordered the studs from Z1. I was just wondering if all 8 of them screw into the head, which is think that they do. Thanks for the info also on the sealant.
1976 KZ900
2006 ZX6R
2006 ZX6R
- andy9802gt
20 Jan 2011 17:08
Yep. All the studs screw into the head. If you don't use flange nuts you'll have to use lock washers on the collars.
'78 KZ1075 LTD
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
- Old Man Rock
21 Jan 2011 16:32
Exhaust clamps 3.5"....
www.jpcycles.com/product/ZZ47320
Selectable sizes....
www.motorcycle-superstore.com/3/13/118/3...aspx?WT.ac=SLIsearch
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
