- Thank you received: 1
Piston Ring question?
- calvin17d
These measurements seem to fall within spec, should the shape be an issue?
Yes circlips are on the way from Z1E.
1976 Kz900 A4
- Motor Head
- Thank you received: 391
How about ring land fit? Rings must fit correctly to the land area of the piston. If the grooves are clean, then a test fit here would be next, then test fit 1 piston with rings installed into the bore, with some engine oil. It will be a bit stiff but you should be able to slide it reasonably easily. If all fits correctly.
- calvin17d
Also the ring/land spec is .06 as standard with a wear limit of .18. my measurement is tighter than spec at .03mm likely due to a bit of carbon.
piston will slide into bore with rings installed.
1976 Kz900 A4
- Motor Head
- calvin17d
One more thing.... I saw you gave some advice to a guy on finding part number 92071-102 (Carb grommets) I have heard the ugly word about it being discontinued and have tried multiple vendors. I got ahold of wired george who said he had hundreds but would not sell parts only install with a carb rebuild which I have nearly completed arleady. Redline cycles has used ones that he is willing to sell, but I'd prefer not go used on this.
This is extremely frustrating, more so than the rings.:S
1976 Kz900 A4
- Motor Head
Or anybody know where?
- andy9802gt
- If it tastes that good, eat it yourself.
- Thank you received: 18
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
- calvin17d
I have found a few posts by other members trying to source this part and have emails out to them as the threads were never followed up with the solution.
1976 Kz900 A4
- calvin17d
That extra 3 hundredths of a mm (.03) is what I need to make spec on the ring/land gap of .06.
How critical is this?
1976 Kz900 A4
- Motor Head
Here is the chart from the FSM for the J's:
Hope this helps.
And no luck so far on the Shaft seals, seems to be NLA.
- andy9802gt
so the ring end gap spec in my manual is listed as standard =.3mm and wear limit = .7. I am at .4ish.
If the standard is .06 and you have a measured .03 you're already tight. If the new rings are .03 thicker than the old looks like you ended up about .06 tighter than the standard= no move-y in the groove-y.:ohmy:
'78 KZ1075 LTD
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
- calvin17d
1976 Kz900 A4
