running to fast
- joboy53
17 Jan 2011 22:36 #423189
by joboy53
running to fast was created by joboy53
so im kinda new to this.. so i apologize in advance
so i started working on my gpz550 last week and i replaced the vavle cover gasket and the head gasket.. i also adjusted the carbs on it (wich i did correctly)
but when i tried to jump start it today it wasint starting at first...:huh: so i started messin with it. it only started with full choke.. and then it bumbed to about six or seven thousand rpms
and i could turn of the choke and rev it and it would stay started but it would try droping to low, so i had to constantly rev it up. oh yeah... and it was running ruff to...
so i dont know whats going on with it. iv been tld it could be the timing but that doesint make sense to me
any ideas??? :huh:
any ideas??? :huh:
- PLUMMEN
- Thank you received: 104
17 Jan 2011 22:45 #423192
by PLUMMEN
Replied by PLUMMEN on topic running to fast
could be many things.
what did you do to the carbs exactly?
- larrycavan
- Visitor
18 Jan 2011 03:48 #423208
by larrycavan
Replied by larrycavan on topic running to fast
Check for vacuum lines not connected.
- stonemaster
- Visitor
18 Jan 2011 04:15 #423211
by stonemaster
Replied by stonemaster on topic running to fast
unless the bike was warm, starting with the choke on isnt that unusual IMO, check idle adjustment and throttle linkage as well, vacuum lines like Larry said, double check carb adj
make a list and do some reading in ur FSM, and dont get excited
same thing happened to me once, I thought I had the carbs adjusted correctly and I didnt, i could see the linkage not returning to position and figured it out
BTW
welcome to the forum
BTW
- joboy53
18 Jan 2011 19:07 #423415
by joboy53
Replied by joboy53 on topic running to fast
i didint do much to the carbs they were allready set right....
and all the air hoses are on right... i triple chacked them...
and i got it pretty warmed up i kept it revved while i had it started and every time i turned it off it still wouldint start without the choke...
um what should i exactly check on the carb?:huh:
- larrycavan
- Visitor
18 Jan 2011 19:26 #423419
by larrycavan
CAM TIMING MABY .....you mentioned you did the head gasket
- hoghaterkaw
18 Jan 2011 19:59 #423425
by hoghaterkaw
Replied by hoghaterkaw on topic running to fast
I'm no friend of those TK carbs but that is the way they they worked from the factory. Full choke to start then you must reduce the amount of choke shortly after the start up to prevent the run away RPMs. Then depending on the air temps you have to wait for some time for the motor to warm up before you can add throttle or ride the bike. Yes syncing the carbs will help some but those carbs made the 550's a cold blooded bike. Also, the 550's were very sensitive to a healthy battery. A weak battery and low RPM's caused either a very rough idle or stalling before the motor fully warmed up. Hope this helps before you tear into the carbs.
- joboy53
20 Jan 2011 22:56 #424045
by joboy53
thanks for the info but im gonna have to do the carbs
so what should i do?? iv never really done anything with one before...(im only 16) lol
- loudhvx
- Thank you received: 1616
20 Jan 2011 23:20 - 20 Jan 2011 23:21 #424050
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic running to fast
Here's a mod to reduce the runaway idle thing and make starts more consistent.
This is only for the 81 gpz550 (and other KZ550's). The later gpz550's are different.
home.comcast.net/~loudgpz/GPZweb/Carbure...PZchokeScrewMod.html
1981 KZ550 D1 gpz.
Other links.
Last edit: 20 Jan 2011 23:21 by loudhvx.
- joboy53
22 Jan 2011 11:59 #424389
by joboy53
yeah mines an 82
