Discolored camshaft cap?
- KZCM
I pulled my cylinder head cover today to check valve clearances. It all looks pretty good for being 30 years old but one of the camshaft caps has me puzzled. All are clean except the cap over the area of the #3/#4 cylinders. It looks like a caramel color like the oil has been baked on. Any ideas what might cause this?
1977 KZ1000 - Wish I still had it
1980 KZ1000E2 - My project
- KZCM
- MFolks
- Thank you received: 540
Do the exhaust pipes look like they ran too lean?
- KZCM
- PLUMMEN
- Thank you received: 104
- larrycavan
- Visitor
Spark plugs all look good. Hard to tell on the exhaust as they're pretty badly discolored all the way across.
They generally get like that from the engine oil being over heated. Since it localized to one cap, I would venture to guess #4 exhaust valve had been run tight for a while at some point and the oil was in need of changing.
Also, I can tell by the top idler sprocket that it's a smog motor head. They'll generate more heat right in the bowl of the exhaust port because of the fresh air charge they get through the air port to continue the burning of exhaust gases in the port.
Dam tough motors I just took a head apart recently that had all 4 exhaust valves bent....but it ran.
- KZCM
- Jack
- Thank you received: 7
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
- Motor Head
- Thank you received: 391
That sounds like a very good Idea to me, in case it has spun or otherwise lacking lube. Oil hole on bottom bearing to head alignment? Possibly the cap is on backwards, missing a dowlpin or in the wrong position? Should have #4 arrow facing forwards.probably nothing,maybe pop cap off and check bearing for sign of getting hot
- KZCM
- KZCM
- PLUMMEN
you can mount a 73-78 valve cover on there if you want,just plug the smog holes in headDoes that mean I could track down a different cover and bypass / remove all the emmissions equipment?
