Removing Stuck Kerker Baffle
  • Marneman
  • Marneman's Avatar Topic Author
17 Jan 2011 15:18
#423044
I'm cleaning up an older Kerker can and want to remove the baffle for clean up. I can't get it to budge. Any ideas?
77 KZ1000-A1 "Bushido" Project
82 KZ1000 LTD "Terri Lee"
You know what, I don't have a one to some other number of douche-bag scale. So.. Six!
  • TexasKZ
  • TexasKZ's Avatar
  • Away
Re: Removing Stuck Kerker Baffle
17 Jan 2011 15:21
#423046
penetrating oil, heat, patience.
  • z1kzonly
  • z1kzonly's Avatar
17 Jan 2011 15:35
#423050
"PB Blaster", this is one of the best penetrants.
Soak it a couple times a day, for a few days. Use the whole can. Tap on it with a hammer for vibration, more PB, it will come out!
  • Marneman
17 Jan 2011 15:38
#423052
Thanks for the suggestions guys. Sounds like it should do the trick. I committed a sin and didn't look for a similar topic already posted. Here is one from 3+ years ago:
kzrider.com/index.php?option=com_kunena&...d=2&id=124253#124483
Thanks again.
  • Marneman
17 Jan 2011 18:12
#423131
BTW, PB Blaster and a block of wood made quick work of it! :)
  • Kawi // Twin
  • Kawi // Twin's Avatar
18 Jan 2011 14:25
#423322
I have a Kerker in that same condition for my KZ650. Are you going to re-chrome it or coat it? Just curious and to see how it turns out.
1978 KZ650 B2
forums.kz650.info/index.php?topic=3569.0
2009 Kawasaki 650R - yes it is a Ninja, but not really
1985 Ninja 900 or GPz900 for everyone else outside the USA
1984 Ninja 900 for restoration
  • z1kzonly
  • z1kzonly's Avatar
18 Jan 2011 14:52
#423328
Glad to see good outcomes.
  • thomas 62864
  • thomas 62864's Avatar
18 Jan 2011 16:41
#423368
take 2 inchs off,at the end of pipe,saving the baffle screw hole.run it open,loud pipes save lives..a harley runs open pipes,old school,why not you ,i do open and proud to be loud.it looks old,like my pipe is.wouldn,t do it to a better one..later,...
  • Marneman
18 Jan 2011 17:20
#423379
The plan is to ceramic coat it. My father-in-law used to run a chrome shop and it is actually more expensive. Too bad I waited too long to make a decision ;)
I actually like the ceramic coated look better too. I've read the going rate seems to be around $125 for just the pipe if you shop around.
I'll post up some pics when I get it done.
  • TexasKZ
  • TexasKZ's Avatar
  • Away
18 Jan 2011 17:51
#423388
Have you been paying attention to what is going on in California and soon elsewhere?
www.motorcycle-usa.com/2/8064/Motorcycle...nia-Exhaust-Law.aspx
latimesblogs.latimes.com/greenspace/2010...ycle-noise-bill.html
www.ph.ucla.edu/mc/exhaust.html
  • PLUMMEN
  • PLUMMEN's Avatar
18 Jan 2011 18:24
#423403
Thanks again.
yeah i like wiremans aproach! :woohoo:
  • Marneman
18 Jan 2011 20:18
#423429
Gotta please the bluehairs.... Would have thought that Cali has some bigger problems to sort out. Glad they are focusing on the really important issues.
