- Thank you received: 18
broken dowel pin
- stonemaster
- Visitor
there should be laws allowing for unpunished execution of PO's
- andy9802gt
- If it tastes that good, eat it yourself.
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
- stonemaster
- Visitor
its number 11 the photo dont show the hole it fits into but its there, aligns advance unit to crank
www.bikebandit.com/houseofmotorcycles/19...1/o/m17211#sch550108
- z1kzonly
- Thank you received: 540
- cyclhed
Past:
1972 175 F7
1974 KZ400
1981 GPZ550
1980 KZ750 LTD
1978 KZ1000
1968 H1500 Mach III
Present:
1982 KZ1000 M2 CSR
- stonemaster
- Visitor
Mine was the same way when I removed it to lube the advancer, but the one in my 82 kz1000m2 was a roll pin. I screwed a small sheet metal screw into the hole and pulled it out. It doesn't hold anything, just locates the advancer so if you can position the advance and torque the bolt it will stay there. If you can't work it loose and pull it you will have to drill it.[/quote
thats what I thought, my jap indie friend said other wise, I guess anyone can be wrong, its just there for alignment
I will try to get it out but i aint worrying to much
thanx man
- stonemaster
- Visitor
