ngk plugs
  • lemo32
  • Topic Author
  • The Price of Cool aint cheap
24 Apr 2006 17:08 #42298 by lemo32
ngk plugs was created by lemo32
I was at the auto parts store today and they told me
ngk plugs are backwards, meaning a number 8 plug would be hotter than a number 9. my manual says that a 9
plug would give a modest performance gain which
would be wrong. This wouldnt be the first time
my manual has lied to me, what i want to know has anybody ran an 7 ngk?this would be on the 900
76 kz model. these
1979 kz 1000 06 katana 750
24 Apr 2006 19:21 #42342 by 1045
Replied by 1045 on topic ngk plugs
Go the NGK web site, it will explain it all
1045
1045
25 Apr 2006 06:24 #42461 by wiredgeorge
Replied by wiredgeorge on topic ngk plugs
Your manual said using the wrong heat range would give you a performance gain? Hmmmm
If you have a 1976 KZ900, use NGK B8ES ONLY or use Nippon Densu (ND) plugs. The NGK are much easier to get around where I live and that is the only plug I use.
The heat ranges are sort of backwards on NGK plugs with the 7 range being "hotter" than the "8".
The purpose of a spark plug is:
1. fire spark
2. conduct heat out of the combustion chamber
3. burn hot enough to burn crud out of a combustion chamber
People occasionally use hotter plugs to burn off excessive carbon build up caused by a weak ignition (weak spark) or improper air/fuel mixture. This is a band aid fix and itself leads to problems. Use the correct heat range and fix problems causing the sooting. Changing the heat range to a hotter or colder range MAY be warranted in extreme temperature conditions but in ordinary use, the Kawasaki recommended heat range for your bike works best. In your case that is a B8ES plug!
27 Apr 2006 11:19 #43179 by MDawnz1
Replied by MDawnz1 on topic ngk plugs
1. fire spark
What he says , unless you are have a problem ........
ALWAYS tune to your plugs
1974 Z1a, still 903
27 Apr 2006 11:44 #43186 by steell
  • Duck
  • e vica na i sau na ga
27 Apr 2006 13:27 #43198 by Duck
Replied by Duck on topic ngk plugs
...they told me
ngk plugs are backwards, meaning a number 8 plug would be hotter than a number 9...
NGK plugs are not backwards. Increasing number corresponds to cooler plug for all(that I've ever seen) brands.
-Duck
27 Apr 2006 14:09 #43211 by BARNEYHYPHEN
Replied by BARNEYHYPHEN on topic ngk plugs
If I were using an NGK "8" on an 8:1 compression ratio engine, (Stock 1976 KZ900) should I move up to an NGK "9" if I make modifications that result in my compression ratio moving to 10:1?
27 Apr 2006 14:23 #43214 by kx_125_pilot
Replied by kx_125_pilot on topic ngk plugs
when i went to buy plugs for my kz, only one was available from ngk.....and that was the iridium....it didn't show a standard plug for it
27 Apr 2006 15:35 #43232 by Willo46
Replied by Willo46 on topic ngk plugs
The NGK website shows a B7ES for a KZ440 LTD.
www.ngksparkplugs.com/index2.asp?country=US&nav=a0000
27 Apr 2006 18:51 #43279 by Jeff.Saunders
Replied by Jeff.Saunders on topic ngk plugs
I would stick with 8's unless you have a need to move up the range. I've run 8's in most of the Z1's I've ever owned - the only exception is my turbo bike - I run 9's in that as the bike runs VERY hot. The key is your plug color - if it's a nice tan color then stay with 8's.
I will occasionally switch a bike to 7's if it's burning oil - just to try and keep the plugs clear.
This email address is being protected from spambots. You need JavaScript enabled to view it.
www.z1enterprises.com
Z1 Ent on Facebook,
28 Apr 2006 10:26 #43422 by kx_125_pilot
yea, i know...but for some reason kawasaki was only showing the iridium plug
28 Apr 2006 10:33 #43424 by BARNEYHYPHEN
Jeff, Thanks for the advice. The #20's are on their way back to you.
