ngk plugs
  • lemo32
  • lemo32's Avatar Topic Author
  • The Price of Cool aint cheap
ngk plugs
24 Apr 2006 17:08
#42298
I was at the auto parts store today and they told me
ngk plugs are backwards, meaning a number 8 plug would be hotter than a number 9. my manual says that a 9
plug would give a modest performance gain which
would be wrong. This wouldnt be the first time
my manual has lied to me, what i want to know has anybody ran an 7 ngk?this would be on the 900
76 kz model. these
1979 kz 1000 06 katana 750
  • 1045
  • 1045's Avatar
Re: ngk plugs
24 Apr 2006 19:21
#42342
Go the NGK web site, it will explain it all
1045
1045
  • wiredgeorge
  • wiredgeorge's Avatar
Re: ngk plugs
25 Apr 2006 06:24
#42461
Your manual said using the wrong heat range would give you a performance gain? Hmmmm
If you have a 1976 KZ900, use NGK B8ES ONLY or use Nippon Densu (ND) plugs. The NGK are much easier to get around where I live and that is the only plug I use.
The heat ranges are sort of backwards on NGK plugs with the 7 range being "hotter" than the "8".
The purpose of a spark plug is:
1. fire spark
2. conduct heat out of the combustion chamber
3. burn hot enough to burn crud out of a combustion chamber
People occasionally use hotter plugs to burn off excessive carbon build up caused by a weak ignition (weak spark) or improper air/fuel mixture. This is a band aid fix and itself leads to problems. Use the correct heat range and fix problems causing the sooting. Changing the heat range to a hotter or colder range MAY be warranted in extreme temperature conditions but in ordinary use, the Kawasaki recommended heat range for your bike works best. In your case that is a B8ES plug!
  • MDawnz1
  • MDawnz1's Avatar
Re: ngk plugs
27 Apr 2006 11:19
#43179
1. fire spark
What he says , unless you are have a problem ........
ALWAYS tune to your plugs
1974 Z1a, still 903
  • steell
  • steell's Avatar
Re: ngk plugs
27 Apr 2006 11:44
#43186
  • Duck
  • Duck's Avatar
  • e vica na i sau na ga
Re: ngk plugs
27 Apr 2006 13:27
#43198
...they told me
ngk plugs are backwards, meaning a number 8 plug would be hotter than a number 9...
NGK plugs are not backwards. Increasing number corresponds to cooler plug for all(that I've ever seen) brands.
-Duck
  • BARNEYHYPHEN
  • BARNEYHYPHEN's Avatar
Re: ngk plugs
27 Apr 2006 14:09
#43211
If I were using an NGK "8" on an 8:1 compression ratio engine, (Stock 1976 KZ900) should I move up to an NGK "9" if I make modifications that result in my compression ratio moving to 10:1?
  • kx_125_pilot
  • kx_125_pilot's Avatar
Re: ngk plugs
27 Apr 2006 14:23
#43214
when i went to buy plugs for my kz, only one was available from ngk.....and that was the iridium....it didn't show a standard plug for it
  • Willo46
  • Willo46's Avatar
Re: ngk plugs
27 Apr 2006 15:35
#43232
The NGK website shows a B7ES for a KZ440 LTD.
www.ngksparkplugs.com/index2.asp?country=US&nav=a0000
  • Jeff.Saunders
  • Jeff.Saunders's Avatar
  • Vendor
  • Vendor
Re: ngk plugs
27 Apr 2006 18:51
#43279
I would stick with 8's unless you have a need to move up the range. I've run 8's in most of the Z1's I've ever owned - the only exception is my turbo bike - I run 9's in that as the bike runs VERY hot. The key is your plug color - if it's a nice tan color then stay with 8's.
I will occasionally switch a bike to 7's if it's burning oil - just to try and keep the plugs clear.
This email address is being protected from spambots. You need JavaScript enabled to view it.
www.z1enterprises.com
Z1 Ent on Facebook,
  • kx_125_pilot
Re: ngk plugs
28 Apr 2006 10:26
#43422
yea, i know...but for some reason kawasaki was only showing the iridium plug
  • BARNEYHYPHEN
Re: ngk plugs
28 Apr 2006 10:33
#43424
Jeff, Thanks for the advice. The #20's are on their way back to you.
