- Thank you received: 1
Swapping Chain drive to shaft
- kz1100warrior
16 Jan 2011 23:39 #422879
by kz1100warrior
Swapping Chain drive to shaft was created by kz1100warrior
Good Day folks.
Here is a question please...
I have KZ1100 SHAFT 1981. I need to swop the engine around...I also have a gpz 1100 chain drive....
So can one swop the clutch mounting from the gpz1100 to make it to a shaft drive instead of chain....My frame is shaft so want to keep it like that.....Thanks
- Nebr_Rex
- Thank you received: 300
17 Jan 2011 00:36 #422884
by Nebr_Rex
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
Replied by Nebr_Rex on topic Swapping Chain drive to shaft
Why do you need to swap engines around?
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- kz1100warrior
17 Jan 2011 00:40 #422885
by kz1100warrior
Replied by kz1100warrior on topic Swapping Chain drive to shaft
i have a melted piston in my barrel, the conrod is buggered, the barrel is broken, i can get a GPZ1100 for nothing, same year, same engine, just different on chain drive......
- Nebr_Rex
17 Jan 2011 00:57 - 17 Jan 2011 00:58 #422887
by Nebr_Rex
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
I think you'll have to split the cases to change the transmission shafts.
Are you in the U.K.?
It is 4 a.m. eastern Here.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
Last edit: 17 Jan 2011 00:58 by Nebr_Rex.
- kz1100warrior
17 Jan 2011 01:02 #422888
by kz1100warrior
No in south africa...here 11am lol
- Nebr_Rex
17 Jan 2011 01:16 #422889
by Nebr_Rex
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
Do you know of the differences between the KZ and GPZ engines?
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- mookieo2
18 Jan 2011 16:10 #423351
by mookieo2
Replied by mookieo2 on topic Swapping Chain drive to shaft
If you lived in the us I would swap my shaft drive for your chain drive.
