Exhaust questions
- ditchdriver
Exhaust questions
15 Jan 2011 05:13
ok im looking for a 4 to 4 exhaust for my 82 kz 550 ltd i found a set on ebay for a kz 750 do you think they will work. If not where is a good place to find a set i have been looking online for 3 weeks because here before long im gonna start trying to fix mine up and i would like the look of the 4-4 better tyhan the stock 4-2
1982 kz 550 ltd
Grand Forks, ND
Grand Forks, ND
- JMKZHI
Re: Exhaust questions
15 Jan 2011 06:15
You've been looking for three weeks? Sometimes with these old bikes, if there's something you really want or need, you have to search for months and months.
You found a 4-intio-4 exhaust system for a KZ750? Can you post a link or at least a photo? Although my knowledge is limited, the only bike I'm aware of with a 4-4 is the Z1.
For a direct fitment to the exhaust ports, I believe you'll have to get something from a 550. Most (all?) of them are 4-into-2. I guess there might be a 4-1 on a GPz.
- Mcdroid
- Gone Kwackers
15 Jan 2011 07:06
Do you mean a 4into4 like on a Z1? Unfortunately, the array of exhausts available for a 550 is fairly limited. You must use an exhaust specifically for a 550...the cylinder spacing is unique...I'm not aware of a 550 4into4 ever being made (but I've been wrong before)...but I have seen 4into2 and 4into1...just like JMKZHI stated.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- TeK9iNe
- What did you do!?!
15 Jan 2011 07:19
As previously stated, I've never seen one.
You will likely be searching for years.
If you measure the dimensions you require, then you could probly find a pipe for something else and bend/manipulate it into something you can use.
An origional 550 Exhaust can be cleaned up and rechromed just fine as well.
4 into 4 = Lots of bottem end torque, good mid range.
4 into 2 = Good low end torque, lots of mid, some high.
4 into 1 = OK low end torque, good mid range, lots of high end power.
Depends on what you want.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- ditchdriver
18 Jan 2011 10:16
thanks guys for the help
1982 kz 550 ltd
Grand Forks, ND
Grand Forks, ND
