Ground Clearance
  • kool4kawis
  • kool4kawis's Avatar Topic Author
  • live is just evil in the mirror
Ground Clearance
14 Jan 2011 20:47
#422262
Hey guy's, got a question about exhaust collectors.I'm building a pro street kz 1000, strecthed the neck 3", dropped it 2" and raked it to 35 degrees. It has front and rear suspension off a 04' zx636. When I put it on the table for surgery I set the frame rails for 7" of ground clearance. Now that I put the 4 into 1 headers on it I only have 2 1/2 of clearance under the bike. So here's my question; would there be a significant loss in performance if I built a flat 4 into 1 collector instead of using the original "stacked" 4 into 1. I dont want to have to raise the bike and dont want to go to a 150/80/17 front tire instead of the 120 thats on there now
  • TexasKZ
  • TexasKZ's Avatar
Re: Ground Clearance
14 Jan 2011 20:58 - 14 Jan 2011 21:02
#422266
A sidewinder exhaust will solve the problem. The whole system goes around the right side.
Check here
www.schnitzracingstore.com/catalogs/cata...93307&showprevnext=1
Last edit: 14 Jan 2011 21:02 by TexasKZ.
  • kool4kawis
14 Jan 2011 21:00
#422267
yeah but I built forward controls for it so they would be in the way of a sidewinder
  • TexasKZ
  • TexasKZ's Avatar
14 Jan 2011 21:05
#422272
Well, ok. How about this?
www.x-pipe.com/motorcycle.html
  • kool4kawis
14 Jan 2011 21:09
#422274
looked into those. they are nice pipes but way out of my price range. That collector is what I was thinkin of just didnt know if there was a significant loss in power over the standard type collector. This is by no means a drag bike but I would like the best performance from the pieces I already have
  • TexasKZ
  • TexasKZ's Avatar
14 Jan 2011 21:26 - 14 Jan 2011 21:27
#422279
I suspect that a flat chamber will make no difference as long as it is as high as the diameter of each individual pipe and has the same volume as a round collector. LarryC and OMR know a lot more than I do about this. Maybe you should ping them.
Last edit: 14 Jan 2011 21:27 by TexasKZ.
  • kool4kawis
14 Jan 2011 21:51
#422287
thanks for the info
  • PLUMMEN
  • PLUMMEN's Avatar
15 Jan 2011 00:15
#422324
find stock exhuast for a z1r
  • les holt
  • les holt's Avatar
  • Vendor
  • Vendor
17 Jan 2011 14:02
#423025
I understand the dropped it 2" and raked to 35 deg. but can you explain the neck streched 3"? As for the exhaust problem, go turbo.:woohoo:
