- Thank you received: 104
Heads vs piston kit vs stock??
- hocbj23
- Visitor
- PLUMMEN
dont worry bj,as we speak omr/old man racen is developing the the cure for bs34 carb performance issues!Did the deal include ur donating a set of BS34s for Larry's boat anchor bidness?bj
hes developing an electric shifter operated off a vacuam/pressure switch from a goodman furnace.
when the switch senses a drop in vacuam it closes the normally open side of a relay(spare coil mod parts)which sends 12v to the electric shifter with the actuator reversed so it actually downshifts 2 gears to put you back in that sweet spot between 5250-5275 rpms!
no pictures of prototype yet,but hes busy back at the new skunk works facility. :woohoo:
- stonemaster
- Visitor
I did get a set of 29mm smoothbore from WG, and u know what those cost OUCH
Goodmans are good units, installed one in mi casa last year
- 31goodtymes31
1979 Suzuki GS1000
1978 KZ1000 LTD
1977 kz1000 A1
1978 Kz1000 a2
2009 Yamaha vmax
- 31goodtymes31
1979 Suzuki GS1000
1978 KZ1000 LTD
1977 kz1000 A1
1978 Kz1000 a2
2009 Yamaha vmax
- kz1k
- You Cant Fix Stupid!
i went with valve job, stock cams, getting new piston kit with 1075 bore. welded crank, and thats about it for all the $$$ stuff. good luck, and keep us posted.
1978 KZ1000A2
- Nebr_Rex
- Thank you received: 300
Oil leaks?
Smoke?
Have you done a compression test?
If compression isn't up to spec is the valve lash to tight?
If it is in good running order you might be happy with some drop in cams, exhaust and intake mods.
That would require money and skills.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
- 31goodtymes31
1979 Suzuki GS1000
1978 KZ1000 LTD
1977 kz1000 A1
1978 Kz1000 a2
2009 Yamaha vmax
- 31goodtymes31
This is my "garage"
and this is bike
1979 Suzuki GS1000
1978 KZ1000 LTD
1977 kz1000 A1
1978 Kz1000 a2
2009 Yamaha vmax
- 31goodtymes31
1979 Suzuki GS1000
1978 KZ1000 LTD
1977 kz1000 A1
1978 Kz1000 a2
2009 Yamaha vmax
- PLUMMEN
a good gsxr 750-1000 swingarm will fit stock pivot area and just needs shock mounts welded on and shims made for it,if you can find 82-83 gs1100 arm its even easier.
the suzuki arms average 1 1/2-2" over depending on which one you get.
just remember drag bikes are made to go in a straight line really fast,and tend to take corners at around 10-15mph
- 31goodtymes31
I bought a dyna s ignition from a guy in the city here for $100 brand new still in the box. I bought new coils and wires from z1 too. Is that what you are talking about?
1979 Suzuki GS1000
1978 KZ1000 LTD
1977 kz1000 A1
1978 Kz1000 a2
2009 Yamaha vmax
