Nooooooo
  • Max2022
  • Max2022's Avatar Topic Author
Nooooooo
24 Apr 2006 10:31
#42171
Have a nice new oil leak after I changed from Synthetic to Mineral GTX 10w-40. I'm hoping it is from the rpm tach reader thing, and I know for sure it isn't from the Clutch cover because the bike is leaning to one side and all the oil is away from the basket. Maybe I just put too much in.
Were should I start looking? The bike is so dirty I think I am going to pressure wash it today or tommorrow because right now it looks like the leak is everywhere, but it seems to be from the left side of the bike, condensing around the oil pan and left most part of the frame and dripping down. It's not the oil pan screw, I tightened that sucker for sur.
  • kx_125_pilot
  • kx_125_pilot's Avatar
Re: Nooooooo
24 Apr 2006 10:52
#42181
wash it really well, take it for a ride and then lightly dust flour around places where you think it might leak.......then wait a bit and it will show
  • Nevco48
  • Nevco48's Avatar
Re: Nooooooo
24 Apr 2006 13:01
#42230
What's that joke about "Roll 'em in flour and look for the wet spot?"
  • kx_125_pilot
Re: Nooooooo
24 Apr 2006 16:49
#42294
i thought we were lookin for oil leaks here:P
  • rammy
  • rammy's Avatar
Re: Nooooooo
25 Apr 2006 05:29
#42446
Good Ole synthetics they will find the smallest spot to seap from.Myself I stay away from synthetic oils for that reason and it played havoc with my started clutch sprag causing to slip and make all kinds of noise and leaks.Just my $.002
The barn yard;77 Kz650B-1 Kaw(the fun one) & 89 classic hog.
Chicago area-south burbs
  • Biquetoast
  • Biquetoast's Avatar
  • King Jeremy The Wicked
Re: Nooooooo
25 Apr 2006 05:33
#42448
rammy wrote:
Good Ole synthetics they will find the smallest spot to seap from....
...but Max did the opposite and seems to have experienced this issue.
:huh:
(1.) '75/'76 KZ400D - Sold
(4.) '75 KZ400D - Sold
kz750twins.com
  • donthekawguy
  • donthekawguy's Avatar
Re: Nooooooo
25 Apr 2006 05:37
#42450
It could be coming out of the stator housing.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
  • Max2022
Re: Nooooooo
25 Apr 2006 22:32
#42709
It's coming out of the left rear cam cover, and maybe somewhere else. Could this be because I put too much oil in the engine?
  • savedrider
  • savedrider's Avatar
  • 1975 Z1-B 900
Re: Nooooooo
25 Apr 2006 22:47
#42714
The cam cover leak is not from an overfill.
Get right or get left! <*{{{><
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
Re: Nooooooo
25 Apr 2006 22:53
#42717
Hmmm... don't know about the "Too much oil" thing(don't think so),but You SHOULD make sure that You have the proper amount in the engine.
How do Your cam-cover plugs look?If You're not sure what they are,they're the half-round,black caps on the ends of Your cover/head.Do they look old and have tiny spider-cracks in them?Does it look like the oil is leaking from them,or higher up,at the gasket?
1977 KZ1000 A-1
  • kx_125_pilot
Re: Nooooooo
26 Apr 2006 13:12
#42884
if you put too much oil in the engine, you can blow seals that way.....maybe you blew a seal??
  • arobsum
  • arobsum's Avatar
Re: Nooooooo
26 Apr 2006 14:59
#42915
my 1976 kz900 leaks from the tach drive(wich is on top cover)
then it migrates making you think you have a big leak when you don't. look there first.
