engine and bike identification!!!!!!
  • steveo_4192003
  • steveo_4192003's Avatar Topic Author
  • 77kz650b-1
24 Apr 2006 09:08
#42146
i thought i had a 77 kz650b-1!!!!
but when i looked at the wiring diagram for it , it was missing a few wires ( orng and grn for blinkers ) ect...
now i dont know what i have now, i looked at a b2 and has most of the same wires as what i have.
the only thing it dont show is the green coming off the alt to the regulator. also (the b-2) it only has two wires comming off the alt, were as mine has 3 plus gren for ground, and dont seem to have a rectifier in the diagram!! mine has a rectifier.
maybe some one parted out another bike and used parts on mine???
please help so i can get the right parts if need be!!!
also will frame #s help or engine#s
1977 kz650b-1, 4-2exhaust systetm, pod filters ,jetted 112 main, 17.5 pilot
  • Tazzmann
  • Tazzmann's Avatar
Re: engine and bike identification!!!!!!
24 Apr 2006 09:50
#42157
Check out the model section of KZ650.info and compare the engine number to see what you got.
Post edited by: Tazzmann, at: 2006/04/24 12:51
  • steveo_4192003
  • 77kz650b-1
24 Apr 2006 10:51
#42179
ok went to kz650info site and think i found what i have
i belive some one changed the motor from a c-1 and put in my b-2
heres my numbers i have
frame #kz650b500826
motor # kz650be010252
anyone want to double check this for me???
just to make sure im right!!!
thanks all!
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
24 Apr 2006 12:07
#42209
Your frame and engine #s are from a B1 according to jarle.eltelevest.no/Kawasaki/Series/Z/650/z650p2.htm coming from the Lincon factory.
The numbers are listed backwards on the site, frame are engine #s and vice versa.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2 Project
  • loudhvx
  • loudhvx's Avatar
25 Apr 2006 00:26
#42430
Your alternator has 3 yellow (or white) wires coming out of it plus a green for the field coil (not ground). That makes it a 1977 B1 (or possibly C1). The alternator cover should also have 3 screws in a triangle pattern . That is the give away that it is a 77.
The 77 uses a field coil which is held in with those 3 screws. The 78 and later does not.
Post edited by: loudhvx, at: 2006/04/25 03:35
  • loudhvx
  • loudhvx's Avatar
25 Apr 2006 00:31
#42431
1977
Post edited by: loudhvx, at: 2006/04/25 03:32
  • loudhvx
  • loudhvx's Avatar
25 Apr 2006 00:33
#42432
1978 or later
  • steveo_4192003
  • 77kz650b-1
25 Apr 2006 10:30
#42523
i been looking at all the diagrams and the c-1 is the only one that hase all the wires i have!! hazards ect... but its a b-1 bike. (thats what the frame and motor #s say anyway) but the wiring is different. maybe they had options you get on them?
i do got i figured out for now, enough to make it street legal and run, but was just confused on my modle.
thanks all, and ill get pics up a.s.a.p
p.s maybe wire diagrams are labled wrong?
(not likely but possible)
