Oil Cooler
- stonemaster
Re: Oil Cooler
12 Jan 2011 06:58
u can us a bypass valve on them as well, manual or automatic, takes care of the warm up issue and when not needed, i run one on my other bike with automatic bypass, Jagg makes but I'm sure others do as well
- Motor Head
Re: Oil Cooler
12 Jan 2011 12:06 - 12 Jan 2011 12:07
Here is the "J" motor oiling, the low chart shows the oil cooler will be right after the pump, out of the switch housing and then loop back to the switch housing. @ #11
Last edit: 12 Jan 2011 12:07 by Motor Head.
- ezrider714
Re: Oil Cooler
13 Jan 2011 12:03
It's not that the heavier oil(20-50W) helps cool better ,it's that the heavier oil does not thin out as much when reaching higher temps, therefore providing better protection when temps are higher.
A cooler can never hurt, unless you are always riding in cold temps. But for even these Ohio summers, a cooler can only help extend the life of critical engine components.
EZ
EZ
78 KZ650SR Mine since 79
4-1 Mac Jet Hot coated since mid 80's
Dyna Coils
Saddlebags (I ain't skeered of going nowhere)
Dyna Coils
- stonemaster
Re: Oil Cooler
13 Jan 2011 12:57
it also depend on the engine, even up north if ur running a bored motor and hits in the 90's (which it does these days) there could be issues depending on the size over bore
