Leaking OIl Presuure Switch Housing
  • grumpy56
  • grumpy56's Avatar Topic Author
09 Jan 2011 07:00
#420949
Removed the oil cooler and replaced the oil sensor housing with an OEM unit on my 1982 KZ1000J2. Also replaced the 2 larger O-rings, the smaller one, and the O-ring on the sensor itself. Crunched down the 2 bolts and for the first 20 miles yesterday everything was dry. Then, ut oh, started to leak again. Among other things, does anyone know why that 3rd small O-ring is used on the inside bolt hole and no O-ring on the other? Is there any other thing in that area where I might spring a leak? Difficult to see in there. Also, can't get a torque wrench in there with removing a bunch of stuff. Thanks.
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
1972 Suzuki GT380 (In-Process)
In The Past...71 TM400, 72 H-D SS350, 72 GT380, 75 Z1B, 77 XLH, 79 CB750K
  • Motor Head
  • Motor Head's Avatar
Re: Leaking OIl Presuure Switch Housing
09 Jan 2011 13:10
#421044
That's enough to make you Grumpy!
If it didn't leak at first, then started again, maybe the o-rings you used were not correct? I put a thin coat of silicone seal, just a smear, on my o-rings. Rarely have any trouble. That 3rd small 1 around the bolt hole is an unknown to me, I looked and said WTF how about the other bolt? Anyway looks like practice makes perfect, you'll get it. Remember to clean it all off and recheck where the leak is, a small mirror and light might help. Some like to put powder then look for the wet spot. No fat lady joke!
  • hocbj23
  • hocbj23's Avatar
09 Jan 2011 16:58
#421075
A for real J bike? I have always wondered what one looked like.Nice scooter.bj
  • larrycavan
  • larrycavan's Avatar
09 Jan 2011 18:12
#421090
It's quite possible it's leaking around the brass nipple that the wire connector slides onto. I've seen that more than once :)
  • grumpy56
09 Jan 2011 19:05
#421122
Thank you all. I think I will pull the housing and smear the O-rings with some oil compatible silicone and see what happens. Larry: Are you referring to the pressure switch itself? I hope it is one of these issues and not a leaking base gasket. That would be a HUGE bummer.
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
  • andy9802gt
  • andy9802gt's Avatar
  • If it tastes that good, eat it yourself.
09 Jan 2011 19:20 - 09 Jan 2011 19:21
#421124
Yeah! Fixing a leaky base gasket sucks. Apparently the picture of my bare frame isn't going to post.
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
Last edit: 09 Jan 2011 19:21 by andy9802gt.
  • Motor Head
16 Jan 2011 18:41
#422816
Did you get the problem solved? If so where was it leaking?
  • grumpy56
16 Jan 2011 18:51
#422820
Took it out for about a 15 mile ride yesterday and no leak, but I think the leak will re-appear when it gets hot on a longer ride. Bought some "black" Permatex to smear on the o-rings, but have not yet tried that yet. Will be my only option if (when) it starts seeping again. Still not sure where the leak is coming from, but eventually will find out (I hope).
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
  • MFolks
  • MFolks's Avatar
16 Jan 2011 19:20
#422838
I use spray on foot powder when troubleshooting an oil leak. It will wash off with some soap and water leaving no residue.
