- Thank you received: 300
CAM SPECS?
- Nebr_Rex
Does anyone know the duration of this cam?
It looks to be a shorter duration cam compaired to the GPZ1100 and .385 cams I have.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
- Motor Head
- Thank you received: 391
Don't know about now, but Norris was a big name in the 80's. Loved the Cams I ran in some Big VW motors.
- larrycavan
- Visitor
I have a .395 lift cam with NORRIS KT-1 engraved on it.
Could be a Kawasaki Turbo cam. They made a KT-1 with the following specs.
.408" lift
263 @.020 duration
It probably is pointer than the GPz cam.
They called it a turbo cam with super torque on normally aspirated motors.
Taking the duration spec at .020 into account, it's probably about like an old 8X Andrews.
- Nebr_Rex
Yes the lobes are pointed compaired to the other two.
A little wear over the nose,but they all measure out about the same.(.002)
Going with a 1075 this winter in my shafty and was going to use GPZ for the intake and .385 for the exhaust.
Think I'll try this cam since I'm after all the mid range I can get.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- larrycavan
- Visitor
Thank you Motor Head and Larry for the info.
You're always very welcome
