81' KZ 750-4 Crankshaft Bushings (stock size)
- kzcafe750_24
07 Jan 2011 16:35 #420632
by kzcafe750_24
1981 Kz 750-4 LTD - Wiseco 810 Big Bore,Ported cylinder head, GPZ 750 Cams,Dyna Ignition(DynaS,Green Coils,DRL400 2stage Revlimiter), RC 4 into 1 fitted with Yoshi muffler, ZR550 Swing arm, ZR550 Rear Rim, ZX750turbo front end SuperFlo Dyno Tuned- 68WHP&43WTq(ftlbs)
1986 Honda Rebel 250 (Stock)
1985...
81' KZ 750-4 Crankshaft Bushings (stock size) was created by kzcafe750_24
Hey Guys,
I'm trying to order crank bushings for my bike, but I don't know which color is the stock size. I read a forum about this, but their is no green crank bushing for my bike, the colors are 92028=blue, 92028A=black, and 92028B=Brown, so If anybody know which bushing is the stock size (color), it would be helpful if you could drop me a line.
Thanks Much,
Dylon
Thanks Much,
Dylon
1985...
- steell
08 Jan 2011 08:00 #420715
by steell
Replied by steell on topic 81' KZ 750-4 Crankshaft Bushings (stock size)
They are all the stock size
You have to look at the crank and rods to see what color was used during initial assembly. There is very little difference between the colors, only like 0.001" or so.
- kzcafe750_24
08 Jan 2011 10:53 #420773
by kzcafe750_24
1985...
Replied by kzcafe750_24 on topic 81' KZ 750-4 Crankshaft Bushings (stock size)
Thank You,
I'll check it, and order them today then.
Thanks Much;)
Thanks Much;)
1985...
