oh crap
- 771000KZ
03 Jan 2011 14:31 #419909
by 771000KZ
oh crap was created by 771000KZ
So I was planning on rebuilding my engine, I pulled the head, block and pistons and I noticed that the connecting rods have allot of play in them, they rock back and forth if you grab the small end, not slide, rock. I take it that is not normal? how do I fix it?
- lemo32
- The Price of Cool aint cheap
- Thank you received: 2
03 Jan 2011 14:58 #419914
by lemo32
1979 kz 1000 06 katana 750
Replied by lemo32 on topic oh crap
Should have some rock, side to side, you can use a feeler gauge to check big end rod clearence, should be no more than.024in, if more you will have to send crank off or get a replacement.
- TeK9iNe
- What did you do!?!
- Thank you received: 28
03 Jan 2011 15:28 #419917
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic oh crap
Normal - as said.
Pull up on the rod with one fist, then whack it downward with the other open hand. If you hear a distinct metallic click, then that rod bearing is shot.
Best of luck.
Best of luck.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- keith1
03 Jan 2011 17:36 #419941
by keith1
Replied by keith1 on topic oh crap
not that it means a lot, but roller bottom ends are extremely durable....bike have a lot of miles?...check via the above advice and the manual.....
