crank woodruff key.
- bondy
02 Jan 2011 17:56 #419806
by bondy
9 parts yellow. 1 part blue.
crank woodruff key. was created by bondy
hi, i have a z1000 a1 engine fitted in a z900 frame. the woodruff key has sheared in the alternator taper shaft. i have looked on a couple of online parts catalogues but cant seem to find a part number for it. i want to fix this and get the engine running properly before i start to strip the bike. anybody have some info?
bondy.
bondy.
- Jeff.Saunders
02 Jan 2011 19:49 #419822
by Jeff.Saunders
This email address is being protected from spambots. You need JavaScript enabled to view it.
www.z1enterprises.com
Z1 Ent on Facebook,
Replied by Jeff.Saunders on topic crank woodruff key.
Z1 Ent on Facebook,
- MFolks
- Thank you received: 540
02 Jan 2011 19:59 #419826
by MFolks
Replied by MFolks on topic crank woodruff key.
Woodruff keys are half moon shaped pieces of metal with a matching slot milled in crank shafts.
To remove it, get a hammer and a pin punch the same diameter as the woodruff key. Tap on the very end of the sheared key and it should pop out of the crank shaft.
Make sure the new key is a snug fit with no metal residue from the old one.
- bondy
03 Jan 2011 02:44 #419846
by bondy
Replied by bondy on topic crank woodruff key.
thanks jeff. i have ordered one. top man.
