- Thank you received: 2
KICKSTART!!!
- bearshawk
so my problem is i believe the ratchet gear on the starter and most likely on the start shaft as well, is the only way to get access to these parts by pulling the engine?? i JUST got the bike serviced and it was acting up a little then but now its nearly impossible to start it by kicking.
i honestly think it may be time for a new engine all together but funds are low so the kz may have to sit... (which i feel is a sin)
any help on the issue would be greatly appreciated,
basically when i kick it over it just slides down ticking on the way like the teeth are rounded off...
1978 kz650 sr- long time project/first bike mostly gone
1979 kz659 sr- new acquisition NEXT project GONE
Both 650s combined to make one great bike! with a new powerplant
it is a 79 frame, 78 front end, both 78 wheels and brakes, 78 body work and a 80' 750-4 motor with gpz 750 cams and a kerker and...
- TeK9iNe
- What did you do!?!
- Thank you received: 28
Sure it has some nostalgic kinda look, but they dropped them way back in the 80's for a reason
Lots of places sell nice cover plates for after you remove the old kicker crap.
PS. if the bike is hard to start with the kicker right after being tuned up, fire your mechanic!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- bearshawk
thanks for the input!
- Nebr_Rex
- Thank you received: 300
Is the electric start working?
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
- Nebr_Rex
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- bearshawk
not at the moment, i have had a few issues with this bikes electric start, i got it fixed because when i recieved the bike (free) it did NOT work and then i had it fixed, and it worked great, now this riding season after i got a new paint job, new tires, new brakes, new exhaust the electric start wont work and the kick starter goes to s$it and kinda cramped my style!
i dont know much about them but i do get a click when i hit the start button however the battery was HORRIBLE so maybe it just didnt have enough juice to kick it over?
- Nebr_Rex
alright thanks for the info,
Yes if it just clicks there is not enough juice to turn the starter,the clicking noise is the starter relay.Check out the charging system and battery connections.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- bearshawk
- stonemaster
- Visitor
- bearshawk
