Header interchangeability KZ1100 with Z900
- gsand
31 Dec 2010 00:29 - 31 Dec 2010 00:31 #419456
by gsand
Header interchangeability KZ1100 with Z900 was created by gsand
Hey lads. Got a quick question, or more of a confirmation.
Bringing a kz1100 back to life and I am lacking headers. My research leads mento believe that the cool Z900/1000 stuff Fits on the kz1100 head fine. Lots of used headers around for the 900 on eBay and all the 1100 bits are standard headers.
A definitive answer would be amazing as I've found some nice 900 headers near by me, just don't want to waste my coin.
FWIW, I already have the header mounting hardware to suit kz1100.
Thanks in advance for all your help
Last edit: 31 Dec 2010 00:31 by gsand.
- BSKZ650
- Thank you received: 14
01 Jan 2011 06:23 #419578
by BSKZ650
77 ltd1000, current rider
76 kz900, just waiting
Replied by BSKZ650 on topic Header interchangeability KZ1100 with Z900
Im not real sure about the spacing between the cyls being the same, I thought the 1100 was wider than a 900 or 1000, I do know the mounting of the muffler would prob need to be custom made , I have never put a header on that didnt require some type of mod
- flhwesty
- Thank you received: 5
01 Jan 2011 07:42 #419587
by flhwesty
1983 GPZ750
1977 KZ1000LTD
1978 Z1R
1981 GPz1100 KZ1100-B1
Replied by flhwesty on topic Header interchangeability KZ1100 with Z900
I think it will work. I have a 82 gpz1100, I am hoping to put a header from a kz900 on it this summer. I understand I will have to rig the mounting hardware, but at the head should be good.
1983 GPZ750
1977 KZ1000LTD
1978 Z1R
- trianglelaguna
- Thank you received: 235
01 Jan 2011 09:46 #419596
by trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
Replied by trianglelaguna on topic Header interchangeability KZ1100 with Z900
the heads off ALL kz-J,kz, z1 models will swap their pipes no problem,..the sweeps/bends will be okay too...the area from the drivers peg back is where the hanger changes start but can be made with hanger clips
1976 KZ900
2003 ZX12R
2007 FZ1000
- gengomerpyle
- Thank you received: 17
01 Jan 2011 10:34 #419604
by gengomerpyle
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
Replied by gengomerpyle on topic Header interchangeability KZ1100 with Z900
will a header from a kz1000 fit a 82 gpz750? i would like to change mine but its hard to find a decent header for a gpz750 at a good price.
1982 GPZ750R1 ELR
1971 Honda CB750K
- gsand
01 Jan 2011 13:22 #419624
by gsand
Replied by gsand on topic Header interchangeability KZ1100 with Z900
Thanks folks, really was the answer i was hoping for. The muffler arrangement is not important, I can do light fabrication but I didn't feel like making a header/collector. The bike currently has open drag pipes made by myself, but not a practical option for the street.
Thanks once again.
Thanks once again.
- racer54
- Thank you received: 114
01 Jan 2011 14:00 #419625
by racer54
Replied by racer54 on topic Header interchangeability KZ1100 with Z900
Headers off a GS suzuki can be made to fit also. They don't match up exactly but they are close. Can't remember which one is wider spacing but I have mounted a GS header on a KZ before. Been told that once on and run for awhile the pipes will take a set to new spacing. Not sure if that's true but something I have heard. Something to keep in mind anyway.
- MFolks
- Thank you received: 540
01 Jan 2011 14:12 #419629
by MFolks
Replied by MFolks on topic Header interchangeability KZ1100 with Z900
The exhaust studs on the Z1 and Kz900 were I belive 6mm, the Kz1000/1100 are 8mm, washers may have to be used to fill potential gaps when tightening down the header clamps(unless you can find matching hardware/clamps).
