kz1000 shift fork shaft???
- Frankn9
30 Dec 2010 22:02 #419444
by Frankn9
kz1000 shift fork shaft??? was created by Frankn9
hello, I am wondering if anyone can tell me if I can get access to the small shift fork shaft on a 78 kz1000 if I go in through the clutch side? the clip on the end of the shaft came off, the shaft slipped in towards the clutch and I can't get it to slide back out so I can put on a new clip. my books say to "tap the shaft out from the clutch side" but thats after splitting the cases. I have the oil pan off but still can't get it. I just want to know if I can get to it before I try to remove the clutch hub and such. So, does anyone know? can it be done? any help would be appriciated, Thanks
Scott
Scott
- gearheadmm
- MUCH MORE BOOST..........I mean BRAVO
- Thank you received: 11
31 Dec 2010 20:00 #419545
by gearheadmm
General Joeseph Dunford FOR PRESIDENT!!!
69.46.28.106/forum/11-projects/413221-80-kz-1000-st-recycled
Replied by gearheadmm on topic kz1000 shift fork shaft???
Normally you go after these from the trans cover side, didn't say if you had it off or not. I'd want to check under there any way. Never heard of that happening.
- Frankn9
01 Jan 2011 00:58 #419567
by Frankn9
Replied by Frankn9 on topic kz1000 shift fork shaft???
trans cover has been removed. the shaft just doesn't want to slide back out, like its catching on the groove for the clip. the bike jumps out of 3rd gear so I took it apart to check things out. everything looks good except the shift fork shaft not in place. the shaft will slide into the case and protrude from the trans cover side just no far enough to get the clip on. Thanks for getting back to me.
- gearheadmm
01 Jan 2011 18:16 #419653
by gearheadmm
Jumping out of gear can bend forks and shafts. Make sure forks move freely.
- APE Jay
- Banned
- Thank you received: 58
01 Jan 2011 19:05 #419663
by APE Jay
Replied by APE Jay on topic kz1000 shift fork shaft???
- Hawk1
18 Mar 2012 20:26 #510510
by Hawk1
Hawk1
Replied by Hawk1 on topic kz1000 shift fork shaft???
I know its old posts, but I was wondering how things ended?
Is this possible or not. I think the same happens here..
Hawk1
