- Thank you received: 3
Broken cam chain guide damaged cylinder. Fix?
- tybolt99
- From where KZs came
30 Dec 2010 15:45 - 30 Dec 2010 15:48 #419395
by tybolt99
82 KZ750 H3
76 KZ900 A4
74 Z1A
73 Z1 (on the shelf)
84 ZN1300
Franklinton, NC
Broken cam chain guide damaged cylinder. Fix? was created by tybolt99
I checked compressions and decided to do top end rebuilt on Z1B. Cam chain guide was broken and bottom end of what's left damaged the bottom of the cylinder where it sit. How should I fix it? Any suggestion?
82 KZ750 H3
76 KZ900 A4
74 Z1A
84 ZN1300
Franklinton, NC
Last edit: 30 Dec 2010 15:48 by tybolt99. Reason: typo
- tybolt99
30 Dec 2010 15:54 #419399
by tybolt99
82 KZ750 H3
76 KZ900 A4
74 Z1A
84 ZN1300
Franklinton, NC
Replied by tybolt99 on topic Broken cam chain guide damaged cylinder. Fix?
82 KZ750 H3
76 KZ900 A4
74 Z1A
84 ZN1300
Franklinton, NC
- kz1k
- You Cant Fix Stupid!
30 Dec 2010 16:13 - 30 Dec 2010 16:14 #419400
by kz1k
1978 KZ1000A2
Replied by kz1k on topic Broken cam chain guide damaged cylinder. Fix?
:S
1978 KZ1000A2
Last edit: 30 Dec 2010 16:14 by kz1k.
- DoubleDub
- Visitor
30 Dec 2010 16:34 #419401
by DoubleDub
Replied by DoubleDub on topic Broken cam chain guide damaged cylinder. Fix?
No expert, but the guide seat will probably have to be welded up and re-machined? Not sure about the piston.
- gearheadmm
- MUCH MORE BOOST..........I mean BRAVO
- Thank you received: 11
30 Dec 2010 18:57 #419420
by gearheadmm
General Joeseph Dunford FOR PRESIDENT!!!
69.46.28.106/forum/11-projects/413221-80-kz-1000-st-recycled
Replied by gearheadmm on topic Broken cam chain guide damaged cylinder. Fix?
Schnitz Racing has the cam drive parts. See how a new one fits. don't look tooo bad. Loose cam chains are hard on all that stuff.
- tybolt99
31 Dec 2010 04:47 #419462
by tybolt99
82 KZ750 H3
76 KZ900 A4
74 Z1A
84 ZN1300
Franklinton, NC
Thank you guys.
I will go to talk to my friend who restores brits to see he can help me. As in the first picture, right side in the pic is grinded some. Must have been running for while with broken chain guide.
I will have to check to see what parts I have to change for whole thing. $350 bike will be who knows how much!
82 KZ750 H3
76 KZ900 A4
74 Z1A
84 ZN1300
Franklinton, NC
- kzryderyahoo
18 Jan 2011 22:53 - 18 Jan 2011 23:00 #423467
by kzryderyahoo
1976 KZ 900
Replied by kzryderyahoo on topic Broken cam chain guide damaged cylinder. Fix?
had a similar issue when doing the last rebuild.
JB Weld with soda can as a form held with duct tape.
just machine the excess flush when cured.
No leaks since.
Make sure you have your JB Weld Certification.
No leaks since.
1976 KZ 900
Last edit: 18 Jan 2011 23:00 by kzryderyahoo. Reason: spelling
- PLUMMEN
- Thank you received: 104
18 Jan 2011 23:23 #423470
by PLUMMEN
Replied by PLUMMEN on topic Broken cam chain guide damaged cylinder. Fix?
get an ebay cylinder
- stonemaster
- Visitor
19 Jan 2011 05:46 - 19 Jan 2011 05:55 #423485
by stonemaster
Replied by stonemaster on topic Broken cam chain guide damaged cylinder. Fix?
I got a Z1 cylinder block (903) I could let go, in good shape, let me know !!!! and it still had the guide in it
Last edit: 19 Jan 2011 05:55 by stonemaster.
- Kidkawie
- I bleed premix
- Thank you received: 245
19 Jan 2011 08:19 #423511
by Kidkawie
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
Replied by Kidkawie on topic Broken cam chain guide damaged cylinder. Fix?
I have a good cylinder off a 74 engine. Bores are clean and within spec.
1975 Z1 900
2004 KX125
- tybolt99
19 Jan 2011 08:54 #423519
by tybolt99
82 KZ750 H3
76 KZ900 A4
74 Z1A
84 ZN1300
Franklinton, NC
Thank you guys.
I have been talking to friend who works on brit bikes. He is really good mechanic/fabricator. I think we can come up with something.
Stone and Kidkawie, thanks. Good to know. I keep it in my mind for the worst case.
82 KZ750 H3
76 KZ900 A4
74 Z1A
84 ZN1300
Franklinton, NC
