- Thank you received: 6
Oil Woes Continued
- grumpy56
29 Dec 2010 12:03 #419152
by grumpy56
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
1972 Suzuki GT380 (In-Process)
In The Past...71 TM400, 72 H-D SS350, 72 GT380, 75 Z1B, 77 XLH, 79 CB750K
Oil Woes Continued was created by grumpy56
Looked all around this morning for a 45 degree "small" fitting as is shwon in the photos. No luck finding one. Does anyone know where to find these puppies? I could really use 2 of them with male-female ends rather than the crimp one shown here. I tried a regular 90 degree but do not have sufficient clearance. Help appreciated.
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
- P21
- Thank you received: 34
29 Dec 2010 12:14 #419155
by P21
Kawasaki KZ 1000 Police (2002) P21
Replied by P21 on topic Oil Woes Continued
could try MSC or MSCDIRECT.COM
sell to the public just sign up
hope that helps
hope that helps
- stonemaster
- Visitor
29 Dec 2010 13:00 #419162
by stonemaster
Replied by stonemaster on topic Oil Woes Continued
try bike bandit
- grumpy56
29 Dec 2010 16:26 #419202
by grumpy56
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
Replied by grumpy56 on topic Oil Woes Continued
If worst comes to worst and I cannot replace this line, do I just block off the side (advacne/clutch) port and this one at the oil pressure switch or is something else required? Gracias.
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
- MFolks
- Thank you received: 540
29 Dec 2010 17:16 #419215
by MFolks
Replied by MFolks on topic Oil Woes Continued
My thinking is you might starve the oil supply to the engine by blocking off the line. I'm sure other guy's will be along soon to answer your question......
- TomW
- Keep the blue side up.
- Thank you received: 52
29 Dec 2010 18:46 #419227
by TomW
'78 KZ1000B2 LTD stock + Vetter Fairing & luggage
'91 ZG1200B5 Voyager XII, stock
Replied by TomW on topic Oil Woes Continued
This little fellow might do you, from McMaster-Carr. I guessed on the size. Other sizes are available. They provide scary fast service.
www.mcmaster.com/#brass-pipe-fittings/=ad5ta1
Tom
Tom
- TomW
29 Dec 2010 18:48 #419229
by TomW
Mmmm... The link wasn't complete. It's part # 53525K47
Tom
Tom
- grumpy56
30 Dec 2010 07:19 #419285
by grumpy56
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
Thanks Tom. Boy, they sure do have what seems to be everything. Once I figure out what sizes I need, that looks like my source.
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
