Starter problem?
  • MAYHEM
  • MAYHEM's Avatar Topic Author
Starter problem?
29 Dec 2010 11:13
#419142
here's the things that I've already tried..
Cleaned connections and installed a new ground cable
New battery
Disassembled starter to make sure gears are ok
The gear in the motor that the starter tins is also ok
...could this be a bad starter clutch? Out of ideas!
  • TexasKZ
  • TexasKZ's Avatar
Re: Starter problem?
29 Dec 2010 11:21
#419146
Sounds like starter clutch to me.
  • andy9802gt
  • andy9802gt's Avatar
  • If it tastes that good, eat it yourself.
29 Dec 2010 14:15
#419174
ayup. starter clutch
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
  • bondy
  • bondy's Avatar
02 Jan 2011 18:28
#419813
mine is doing the same thing. i removed the starter clutch side cover. took the stator off and it turned out to be a sheared woodruff key.
9 parts yellow. 1 part blue.
