gearbox change
- battymatty
23 Apr 2006 15:45 #41901
by battymatty
gearbox change was created by battymatty
hi i am restoring a kz1000 ltd (1980) with a gearbox problem (damaged dogs on third gear pinion - god knows how this happened), i have sourced a reasonable replacement gearbox from a z1b900- are they the same , does anyone know, cheers mat
- wireman
- Visitor
23 Apr 2006 19:47 #41980
by wireman
Replied by wireman on topic gearbox change
should be same parts,how about the rest of that Z1?:whistle: :woohoo:
- battymatty
24 Apr 2006 01:56 #42064
by battymatty
Replied by battymatty on topic gearbox change
i can get you the email adress of the guy thats breaking the z1, but were in the uk- any use... cheers
- wiredgeorge
24 Apr 2006 06:08 #42095
by wiredgeorge
Replied by wiredgeorge on topic gearbox change
Matty, Compare the length of the rods that the shift forks ride on. Something in the back of my memory tells me that they will be different. If your 900 rods are shorter, use the longer 1000 rods so they fit properly. The 900 rods may be shorter and have more play and thus be more prone to breaking.
- battymatty
25 Apr 2006 12:08 #42550
by battymatty
i havnt got a chance to compare the gearboxes and im not sure that the forks, barrel and rods are available- i was just hoping i could use the 2 z1 900 shafts with my existing (z1000 classic)selector bits and bobs- should this work ???
- wiredgeorge
26 Apr 2006 07:56 #42789
by wiredgeorge
The swap SHOULD work but do compare the length of the shafts the forks ride on... seems to me that is where there MIGHT be a difference. I am not sure...
