Turning Polished Aluminum back to normal
- RunDog
28 Dec 2010 17:32 #418963
by RunDog
Turning Polished Aluminum back to normal was created by RunDog
I'm sick of polishing aluminum. I think Ive spent half my life polishing this crap. Thats enough. You can't ever keep it nice. Does anyone know how to turn it back to stock look without waiting five years without polishing. Thanks Go Packers
- stonemaster
- Visitor
28 Dec 2010 17:59 #418969
by stonemaster
Replied by stonemaster on topic Turning Polished Aluminum back to normal
when I saw this I said to myself WTF but of course someone else on the net has thought the same thing
answers.yahoo.com/question/index?qid=20090202195801AAeQOP1
- RunDog
28 Dec 2010 18:01 #418971
by RunDog
Replied by RunDog on topic Turning Polished Aluminum back to normal
Thank you I'm not alone. Do you thing polishing make my bike faster
- stonemaster
- Visitor
28 Dec 2010 18:53 - 28 Dec 2010 18:54 #418986
by stonemaster
no man I was jus kiddin, :silly:
do u think ur dishwasher is big enough ?:laugh:
Last edit: 28 Dec 2010 18:54 by stonemaster.
- RunDog
28 Dec 2010 19:11 #418996
by RunDog
Now that you say it Thats a damn good idea( parts cleaner)never thoght of it Ya think my wife would care maybe I could set one up in my garage. I bet it would work Just run Wd 40 instead of water. you goy my wheels turning
- mjg15
28 Dec 2010 20:04 - 28 Dec 2010 20:11 #419012
by mjg15
'80 Z750fx
'81 KZ550A
'81 GPz550's, Too many!
'82 KZ1000R
'82 GPz750
'90 ZR550
Project photo album: s163.photobucket.com/albums/t289/mg15_ph...GPz-ZR550%20project/
s163.photobucket.com/albums/t289/mg15_ph...current=DSC01286.jpg
Replied by mjg15 on topic Turning Polished Aluminum back to normal
I've used a buffing wheel with scotchbrite sandwiched between two cloth pads. When I'm done with that I use fine steelwool, rubbed in one direction. It usually gives me an OEM look.
I spent about an hour or so on the swingarm in the picture
'80 Z750fx
'81 KZ550A
'82 KZ1000R
'82 GPz750
'90 ZR550
Last edit: 28 Dec 2010 20:11 by mjg15.
- TerryK
- Thank you received: 3
28 Dec 2010 20:08 #419018
by TerryK
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
Replied by TerryK on topic Turning Polished Aluminum back to normal
I know Easy Off oven cleaner works great for restoring rough or sand cast cases. Makes them look new. maybe it will have the same effect on polished aluminum?
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
- P21
- Thank you received: 34
29 Dec 2010 05:07 #419084
by P21
Kawasaki KZ 1000 Police (2002) P21
Replied by P21 on topic Turning Polished Aluminum back to normal
scotchbrite works for me.
steel wool throw that old shit out!
- Gman
- Thank you received: 5
29 Dec 2010 06:42 #419098
by Gman
1978 KZ1000
1965 Harly Electra Glide
2002 Gold Wing
1974 Z1 900 project
Replied by Gman on topic Turning Polished Aluminum back to normal
RunDog,
If you aren't successful in changing it back to normal, I'll offer the method that works for me on maintaining polished aluminum parts. I maintanence my polished aluminum eng covers once a year by waxing them with paste wax. If the shine isn't to my liking, I give it a light buff with Simichrome or something similar and then wax it. The wax seems to keep the polished aluminum from starting to oxidize. Obviously if you use a cleaner that removes wax such as S100, you will have to rewax. I only use mild carwash soap that doesn't strip wax to wash the bikes. But this is a once a year method I don't mind for maintaining polished aluminum. Your results may vary. Good luck with getting it the way you want it.
1978 KZ1000
2002 Gold Wing
1974 Z1 900 project
- kawsakiman
- Thank you received: 6
29 Dec 2010 09:20 #419122
by kawsakiman
Replied by kawsakiman on topic Turning Polished Aluminum back to normal
clean it then use this
www.zoopseal.com/
www.zoopseal.com/
- steell
29 Dec 2010 13:12 #419164
by steell
Replied by steell on topic Turning Polished Aluminum back to normal
Why not paint it with the clear coat from POR-15 designed to protect polished aluminum?
http://wwwhttp://www.repaintsupply.com/pd_GLISTEN_PC_GLOSS_CLEAR_pint.cfm.repaintsupply.com/pd_GLISTEN_PC_GLOSS_CLEAR_pint.cfm][/url]
- RunDog
29 Dec 2010 17:13 #419214
by RunDog
Do not use oven cleaner on spoke rims It will ruin them. Done that
