- Thank you received: 20
pressure waves/rpm
- nads.com
22 Dec 2010 22:37 - 22 Dec 2010 22:41 #418277
by nads.com
pressure waves/rpm was created by nads.com
Moving the collector closer to the engine. Does the pressure wave arrive at the port at a higher rpm? :woohoo: high rpm high rpm high rpm is not complete cannot delete high rpm cannot compete higher higher, faster faster, go, go, go...
Last edit: 22 Dec 2010 22:41 by nads.com.
- nads.com
22 Dec 2010 22:41 - 22 Dec 2010 22:41 #418278
by nads.com
Replied by nads.com on topic pressure waves/rpm
high rpm
- larrycavan
- Visitor
23 Dec 2010 05:48 #418284
by larrycavan
Replied by larrycavan on topic pressure waves/rpm
Think about it.....it's a time/distance deal
- TeK9iNe
- What did you do!?!
- Thank you received: 28
23 Dec 2010 08:41 #418293
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic pressure waves/rpm
Check out 2-stroke pipe tuning for a better understanding, as most of the concepts apply to 4-stroke as well. Theres lots of 2 banger exhaust tuning info out there as it is much more critical for those engines.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Becker
- The Doctor Will Rise Again
- Thank you received: 1
23 Dec 2010 18:07 #418348
by Becker
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
81 CB750K Super Sport
Replied by Becker on topic pressure waves/rpm
It all depends. If you shorten it an inch or two then the power band may move up in the RPM range. Its a maybe because eventually as you go to shorter and shorter the peak horsepower will go back down. Think of it as a sine wave. you can end the pipe at the top of the sine wave or at the bottom. But as you shorten the pipe you will eventually run in to the next wave.
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
- nads.com
24 Dec 2010 13:38 #418456
by nads.com
wave on wave see sine
- Kraz1
24 Dec 2010 19:04 #418502
by Kraz1
Replied by Kraz1 on topic pressure waves/rpm
- hocbj23
- Visitor
24 Dec 2010 19:22 #418504
by hocbj23
Replied by hocbj23 on topic pressure waves/rpm
No sh--.That engine just plain grenaded.Ouch.Did u notice that slick head work?Wow..bj
