front sprocket gear noise.
- kz1k
- You Cant Fix Stupid!
1978 KZ1000A2
- kz1k
1978 KZ1000A2
- kawsakiman
- Thank you received: 6
did you ever have this bike running down the road?
a chain that is too tight will wipe the bearing out quicker then shit.
- kz1k
bike was given to me in parts through craigslist. probably the most exspensive phone call i have made in my life...lol. when i spin the sprocket i watch it slow down and look for an abrupt stop, but it seems to spin well until it comes to a slow roll then stop. its hard to explain. sounds like someone dragging a tool in a hard wood floor if you catch my drift. even though it spins with no drag. i may be over thinking, but i figured i should ask. i noticed barely anyone has replied to this thread making me think i am over thinking this. thanks Joenot right.
1978 KZ1000A2
- Motor Head
- Thank you received: 391
- gearheadmm
- MUCH MORE BOOST..........I mean BRAVO
- Thank you received: 11
General Joeseph Dunford FOR PRESIDENT!!!
69.46.28.106/forum/11-projects/413221-80-kz-1000-st-recycled
- kz1k
since i have the thing apart and need to put a extended sprocket on i might as well replace it. hows it come off?If the output bearing is bad it can lock up and kill you. Motion Industries formerly Berry Bearing might have a website maybe not.
1978 KZ1000A2
- gearheadmm
- kz1k
ill check it out tomm, than ks,,,also i need to find a place that sells a replacement.....z1?Impact the sprocket nut off an it should slide or tap right off.
1978 KZ1000A2
