1000 engine into 650 frame
- sbjones
22 Apr 2006 22:02
ok guys and girls a little up date here.
i am back for working on the '78 650 bike of mine. here is a pic of the mock up engine fitment.
- sbjones
- sbjones
Re: 1000 engine into 650 frame
22 Apr 2006 22:11
i am still working on the solo seat set up and a couple of other things. this bike is going to be a bit different.
i call it franken bike, a little name my past co workers gave to it when i started it all!!!
- steell
22 Apr 2006 22:32
Looking good, USD forks and all
Do you happen to know if the new front end is lighter than the original?
- sbjones
22 Apr 2006 22:53
well i didn't weigh it , but i can tell you by just picking up the front ends. the usd forks are a heck of alot lighter than stock.
- steell
23 Apr 2006 06:30
sbjones wrote:
Thanks
How about some more details on the bike? Like what front and rear suspension are you using? And what (if anything) are you doing to the motor?
Looks like a really cool project and I'd like to know more about it.
If you have already mentioned it in ther threads, then links would be fine
Thanks
- Max2022
23 Apr 2006 08:06
That thing looks sweet! Love the color with the white wheels.
- wireman
23 Apr 2006 09:15
yeah that looks like a pretty deadly combination you got there!
- reborn650
23 Apr 2006 09:40
Hey Steve- ..... Your project looks pretty trick. Man I'd love to be around when one of those 600 cc organ-donor bikes pulls up beside you at the light....That ride is definitely gonna be a super-sleeper rocket. You will probably need to be licenced by NASA when you get everything dialed in. Was there much frame gusseting needed?
Post some more pics as you are crossing the interest levels of most members on this site with a litre motor in a middleweight package. Looking good-Cheers-Colin
'77 Kz 650 Custom - (Miss July on 2006 Kzr Calendar,) Newest rebuild includes Wiseco 810 kit, Kz750 cams, Kz750 intake valves, 750 GPz springs, Ported head, WG Mikuni 28's, Velocity Stacks, Dyna Ignition and coils, MAC pipe, 14 tooth sprocket, going back to original '77 Moon Dust Silver. Goal is to have a stock-looking bike that will tighten up any loose dental fillings off the light.
-1998 Jeep TJ Wrangler 4.0 litre for the kids
-1975 Zamboni - The real Italian sportscar fully restored and functioning every winter at our local outdoor playground rink.
Mine is an ecclectic collection of motorized toys - LOL
I have a newspaper route and a web site where you can plan your own funeral life celebration www.mysendoff.com ....and go out with your own style.
- sbjones
23 Apr 2006 11:20
well MANY of you guys have u2u'd me. so here is the entire project as of now.
1978 kz 650.
2002? (ithink) gsxr 600 entire rear end, i cut and welded the frame to get this to fit right. gsxr 1000 rear sprocket and a 5/8 offset sprocket up front with 530 chain.
2001 front end complete, must swap the steering stem to make fit, then just goes right in. by the way, race tires both back and front, ya know to stick better!!!!
now for the engine since this is the engine forum,
'77 1000 engine bored to a 1075. 10.5:1 compression. 900
crank shaft that is welded. ported and polished head with stainless steel bigger valves. bs 34 carbs that have been tottally reworked by a friend of mine. i have had to cut all of the factory mounting brackets off to get this to fit into the frame.
as for the exhaust. i will have to make a complete exhaust system from scratch since the front end is now dropped down majorly. not so sure about this yet.
if this engine works out good. i have another engine that i have thought about making into like a 1300+ for the street to put into here. maybe in the future.
this project is not for the faint of heart by any means. it has been a pain. but nothing is impossible. i have to say that is how this all started, some one told me that it would "never fit" i had to be hard headed and go for it!!!!!
i do not recommend this to be done again, if i did, i would use a 1000 frame instead of a 650.
i will up date every one as the project progresses.
1978 kz 650.
- sbjones
23 Apr 2006 11:28
as far as frame gusseting, oh yes ther will be alot of that. i haven't done it yet, but it is coming pretty soon. i will get pics of every thing as is gets done.
