- Thank you received: 3
How to tell if a motor has been stroked?
- hardr0ck68
- Who put the what in the where?
Of course it is not in running condition and the origional owner passed away a few years back, and the reciepts are around somewhere but he can't find them
I smell a scam, but if it's not it would be a hell of a deal!
1977 kz650 c1
bought it because I was told it would never run again...I like to prove people wrong.
- stonemaster
- Visitor
- Mark Wing
- Thank you received: 22
Mark
Yorba Linda Cal.
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- lemo32
- The Price of Cool aint cheap
1979 kz 1000 06 katana 750
- kz1k
- You Cant Fix Stupid!
1978 KZ1000A2
- stonemaster
- Visitor
damn didnt think of that one , good mantake out a spark plug and get the piston up to top dead center take a thin piece of welding rod take a measurement or mark the rod with a marker level with the sparkplug hole and then rotate the motor forward until the piston stops the mark the rod again pull it out and measure the distance between the two marks that will be the stroke.
- TerryK
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
- stonemaster
- Visitor
- timebomb33
- hardr0ck68
1977 kz650 c1
- jjdwoodman
- Live free, or die.
You need the plug out, and tdc. use a funnel with a rubber hose that fits into the hole tight. fill er up with oil, and mark the level, then rotate down to bdc and mark again. then you just measure out the oil into a graduated cylinder. Tadah! bore and stroke. Don't forget to blow out the cylinder before you replace the plug.
77 650b
81 550 Mostly there
83 ZN1300 Voyager
