- Thank you received: 225
Hocyakaki Exhaust
- hocbj23
- Visitor
15 Dec 2010 12:51 #417063
by hocbj23
Hocyakaki Exhaust was created by hocbj23
Bet I got your attention with that one:laugh: OK,I am fabbing up a 4 into 1 exhaust for the Radian using a header from a 600 FZR and an open FZR can that I found cheap.Got everything sorta set in place and tacked today so I thought I would fire that mutha up and see how she sounded.Holy Earache Batman-way too loud.So cut a small metal circle that fit up into can,welded long bolt onto it,cut another larger circle for outside edge of can,drilled holes in both,tacked the inner circle in can,bolted outer circle on and ,voila, I have baffles.Started bike again and less loud but still cop attractor.I need help on something to pack the baffles with,Have used fiberglass and steel wool in the past but they burn up pretty quick.anyone got some better stuff I can use.Thanks. I apologize for using this forum for a Yamaha project,but the Radian site has no useful info.bj
- hocbj23
- Visitor
17 Dec 2010 11:38 #417430
by hocbj23
Replied by hocbj23 on topic Hocyakaki Exhaust
Bump for some help.
- Old Man Rock
17 Dec 2010 12:04 #417434
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic Hocyakaki Exhaust
Here you go BJ....
Fiberglass wrap for sport and cruiser baffles...
www.motorcycle-superstore.com/1/4/378/31...aspx?WT.ac=SLIsearch
Have I used this product... No, so unknown results...
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
