my cylinder/piston #'s
- kz1k
- You Cant Fix Stupid!
pistons 1-4 measured 2.596 inches.
piston standard is 2.5956-2.5965 service limit is 2.590 (makes no sense to me)
block 1-4 measured 2.599-2.5995
block standard 2.5984-2.5992 service limit is 2.602
this is like radio instructions to me, anyone tell me if i need to bore my 903 to a 1015 and get a piston kit? or can i put a set of rings? thanks Joe
1978 KZ1000A2
- andy9802gt
- If it tastes that good, eat it yourself.
- Thank you received: 18
well i just picked up my cylinders and pistons from the machine shop. everythings in inches.
you're pistons are fine they get smaller as they wear out thats why the service limit is a smaller number than they measure now. the block is on its way out. At about $70 each you could just resleeve it to the stock bore.
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
- kz1k
1978 KZ1000A2
- bountyhunter
- Thank you received: 337
Subtract these two above and that gives a piston to cylinder clearance of over .003" which sounds a bit loose to me (?)pistons 1-4 measured 2.596 inches.
- kz1k
thats what the machinest said. 3 thou. then with honing i would add another thou.Subtract these two above and that gives a piston to cylinder clearance of over .003" which sounds a bit large to me (?)pistons 1-4 measured 2.596 inches.
1978 KZ1000A2
- DoubleDub
- Visitor
- kz1k
hey man, i got the bike for free, what di i expect?:woohoo:Sounds like you got it under control!
1978 KZ1000A2
- larrycavan
- Visitor
d set up with .002 on the end cylinders and .0025 on the inside pair.
JMO
