- Thank you received: 1
6 speed vs. 5 speed trans
- MuzzleMike
- Rice Only
Mike
82 KZ750 LTD H3
- H1Vindicator
- Thank you received: 53
- turboguzzi
- Thank you received: 72
the 550 drops right in and seemingly has very few issues to resolve to make it work. see pic.
one way to check would be to go to online 440 and 550 g'box parts list and see if these have the same part numbers.
would check also in the tech specs if they have the same ratios
wouldnt be surprised if the the 440 works too
let me know if you need any measurements as my motor is still open
TG
- MuzzleMike
- Rice Only
Turbo What did you have to do to make it work ?
Thanks
Mike
82 KZ750 LTD H3
- hardr0ck68
- Who put the what in the where?
- Thank you received: 3
1977 kz650 c1
bought it because I was told it would never run again...I like to prove people wrong.
- loudhvx
- Thank you received: 1616
I just got done doing some home work . It looks like that the 440 and the 550 are the same parts .
Mike
How did you check they have the same parts? Just making sure you know the part numbers in the diagrams are reference numbers. The full-part number has a 4 digit extension. The first 5 or so numbers only refer to what type of part it is. Many bikes will have part numbers where the first several digits match, but the last 4 may be totally different. In the parts fiche, you have to look at teh parts list to get the full part number. If that's what you checked, then nevermind. I didn't see any matching part numbers in my quick look at 440 and 550 trans parts, but then again the 550 part numbers don't match 750 numbers either (except some of the bearings, which may be the key), so trans's can swap even if the parts have different numbers, but then it's a matter of comparing the physical parts.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- gane
[img][/img] 1977 KZ1000A1
- MuzzleMike
- Rice Only
Mike
I was looking at the bearings I thought as long as the bearings are the same and the input and output shafts line up it should be a shot. Sorry I should have been more clear on it . Like I stated both are in good shape and since I am planning to get into the 750 anyway if there would be a benefit why not try ? And the 440 is nothing but a parts bike so it will no hurt it .
Mike
82 KZ750 LTD H3
- MuzzleMike
- Rice Only
82 KZ750 LTD H3
- turboguzzi
6 speed essentailly reduces gaps, or revs drop between gears.like someone said here, really worth the while if you are going racing as 6 speeds let you match corner speed to revs better and make the most of a tuned engine with a narrow powerband.
I am currently working on the switch to 6spd, it involves some machining of the different spacers, etc. Havent finished it so there still might be surprises. Do it only if you have access to a good machine shop and know what you are doing. It's definetely not a drop in mod and a locked gearbox at 100mph is not a funny thing.
