exhaust question
  • krazinite2003
  • krazinite2003's Avatar Topic Author
exhaust question
12 Dec 2010 11:45
#416561
ok i have an 83 KZ750 L3 now the question is what mufflers would fit from other bikes i have bin lookin at a couple from ebay from an 83 gpz 750 . i want to stay with the 4-2 system
i have two 1983 kz750 L3
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Re: exhaust question
12 Dec 2010 12:36
#416570
Virtually anything from a period 650/750 model will fit the head...fitment issues will arise with the mufflers...you may have to fabricate hangers for the rear portion of the exhaust system.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • JMKZHI
  • JMKZHI's Avatar
12 Dec 2010 14:04
#416578
And a non-stock system might interfere w the center stand, if your bike has one. I guess that could be solved w homemade bracketing - if so hopefully the stand won't hang down too much, causing clearance issues w the ground particularly on sharp left turns.
  • krazinite2003
15 Dec 2010 10:09
#417044
i understand all of this but would mufflers from a 82 750 gpz fit the L3 with out any problems
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
15 Dec 2010 10:16
#417047
They should...but as we have stated, you may have to fabricate different muffler hangers. Despite that KZ750R1 and KZ750L3 being very similar motorcycles, there are some idiosyncratic differences. For example, casesavers for an R1 will not fit L3 cases and vice versa. These differences may extend to how the mufflers attach...I don't know.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • trianglelaguna
  • trianglelaguna's Avatar
15 Dec 2010 10:20 - 15 Dec 2010 10:22
#417048
NO you will have some problems
,,,you will have longer mufflers and no place to hang/support them....if you make hangers form the top shock bolts that "hang" down to the muffler stock mounting brackets,out of some nice straps of aluminum 1/4" x 1" flat stock....then you can support the mufflers.....the head/exhaust ports will line up and are the same diameter (dbl check this with another member but 95 % sure)...the bends under the bike will be okay too...from the drivers foot pegs back is where stuff is gonna get funny and need fabbing....and may in the end look kinda dorky imo
why not hunt around for a nice used header
Edit:
I took another look at your bike..if it is the one in your avatar then you will be okay just a few hangers to fab...you really want pipes from an 82 dual shock gpz imo...but both may work fine
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
Last edit: 15 Dec 2010 10:22 by trianglelaguna.
