99 KZ1000P will crank and has spark, but won't run
- B1379
09 Dec 2010 10:45 #416100
by B1379
99 KZ1000P will crank and has spark, but won't run was created by B1379
My KZ1000P ran perfectly until one morning she wouldn't start. It will crank and has spark and fuel. Battery ok. Coils getting 12.9. Fuses good. Carbs clean. New plugs. WTF???
Any thoughts would be greatly appreciated!
- hocbj23
- Visitor
09 Dec 2010 11:02 #416102
by hocbj23
Replied by hocbj23 on topic 99 KZ1000P will crank and has spark, but won't run
spark +fuel+02=ignition.U didnt mention ur air cleaner element.Clean?Is spark nice and fat and blue or weak orange looking?Plug caps nice and tight on plugs? Switches on the bars clean and working properly?Engine stop switch working properly.Do u have a kill switch on the sidestand?If so is it clean and working properly?Clutch switch working properly?I am sure there are others here with other suggestions.Good luck.bj
- MFolks
- Thank you received: 540
09 Dec 2010 12:10 #416108
by MFolks
Replied by MFolks on topic 99 KZ1000P will crank and has spark, but won't run
I'd suggest checking the input voltage to the ignition coils. If it's down around 8-10 volts, you have a connection problem causing a voltage drop.
To check the voltage, remove the gas tank,get a multimeter, set it on Volts D.C.(VDC)range of 20. Turn on the ignition, and with the RED probe of the multimeter touching the RED wires going to the coils(it goes to both of them)put the BLACK probe on a part of the frame or the Negative battery terminal.
If the battery is in good shape, you should read almost the same voltage.
- B1379
12 Dec 2010 01:52 #416469
by B1379
Replied by B1379 on topic 99 KZ1000P will crank and has spark, but won't run
yup i checked it... 12.9 volts....still baffled by this gremlin! :S
- MFolks
12 Dec 2010 12:26 #416565
by MFolks
For an engine to run you'll need compression,fuel and spark, have just one missing from the list and it won't run.
A new/rebuilt engine might have 180 PSI, get a few years wear and it might be about 160 PSI or so.
An engine will run at 100 PSI but will not produce much power.
Checked the timing with the plugs removed and shined a timing light on the advancer marks?
- gane
- Thank you received: 1
12 Dec 2010 13:02 #416573
by gane
[img][/img] 1977 KZ1000A1
Replied by gane on topic 99 KZ1000P will crank and has spark, but won't run
Mfolks' timing light check is a good one, It takes little time, & while I've never seen it on a Kaw, I've encountered TCI's which would still cause spark, But timing was erratic.G
